Thread started 17 Feb 2008 (Sunday) 06:08
5D Battery discharge
I ­ Simonius
Weather Sealed Photographer
Gallery: 19 photos
Location: On a Small Blue Planet with Small Blue People With Small Blue Eyes
Feb 17, 2008 06:08 |  #1
Is it common knowledge that the 5D battery discharges ( albeit slowly) if left in 'sleep' mode rather than fully turned off?
I notice that when I leave the 5D to auto power down and forget to turn it off completely, when I come back to it afetr a few days of non use, the battery is considerably discharged, even completely so if it has been a week since I used it.
Is this normal - I assumed it was but tought I should ask just in case?
Veni, Vidi, Snappi
Website  (external link) My Gear ---- (external link)
chauncey
Feb 17, 2008 07:31 |  #2
As a new 5D owner, I should know the answer, but I don't.
Nick_C
Feb 17, 2008 07:40 |  #3
I always turn mine fully off when packed away in the bag, it makes sense that it could possibly drain a few millivolts when in standby leading to a depleted battery if left for any length of time in that state though.
Jon
Joined Jun 2004
Feb 17, 2008 09:12 |  #4
Sure it's not "just" an old or dying battery (or charger)? Some of my batteries do just fine for weeks or even months; others seem to die practically as soon as they go in the camera. I really need to get a better handle on which ones are doing what.
Jon
Cocker Spaniels
rumble
Feb 17, 2008 09:36 as a reply to  @ Jon's post |  #5
Why not just turn it off when you're done with it??
The fact that the battery is so forgiving might be the reason that you're not paying attention in the first place.
Sounds like a luxury problem to me.
sapearl
Gallery: 243 photos
Feb 17, 2008 09:52 |  #6
Excellent question - and I don't know the answer ;).
It would make sense though that there would be a small drain, since the camera is "waiting" for you to either focus, meter, zoom, etc. and it has to be minimally powered in some sort of ready mode to sense that depression on the shutter button or other controls.
Any time it goes back in the case I just turn it off - don't see any point in leaving it on unless I've forgotten.... which does happen :rolleyes:.
I Simonius wrote in post #4933753 (external link)
Is it common knowledge that the 5D battery discharges ( albeit slowly) if left in 'sleep' mode rather than fully turned off?.....
MY WEBSITE (external link)- MY GALLERIES (external link)- MY BLOG (external link)
Artists Archives of the Western Reserve (external link) - Board
steved110
Feb 17, 2008 12:35 as a reply to  @ sapearl's post |  #7
My 20d does not discharge noticeably when left in sleep mode, and I almost never turn it off - seems little point .
I would be suprised if the 5D was less well designed in that way than the 20D - how old is the battery?
Canon 6D
Canon EF 50mm f/1.4 , Canon EF 85mm f/1.8 Canon EF 100mm f/2.8 macro
CanonEF 17-40 f/4 L Canon EF 24-70 f/4 IS L and 70-200 f/4 L :D
Speedlite 580EX and some bags'n pods'n stuff
Mark_Cohran
Joined Jul 2002
Feb 17, 2008 13:16 |  #8
The 5D doesn't seem to draw any more power in sleep mode than any of my other cameras. I usually turn mine off when it's put away for storage, but on occasion I've forgotten and when I returned to the camera it's powered up and lasted quite well.
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Forty years of shooting and still learning.
My Twitter (external link) (NSFW)
Follow Me on Instagram (external link)
Pete
Feb 17, 2008 13:37 |  #9
The battery in my 5D seems to last for weeks on end, regardless of wether it's being used or not.
Pete
UK SE Catch of the Day
I ­ Simonius
Gallery: 19 photos
Feb 17, 2008 17:05 |  #10
Jon wrote in post #4934345 (external link)
Dunno, I have 4 batteries. 2 Canon and 2 jessops. The Jessops ones definitely fade sooner than the Canon ones, however they are all only 18 montths old and don't get heavy use
rumble wrote in post #4934446 (external link)
it's no harder to make an intelligent comment or to read the question properly:rolleyes: - try it;)
sapearl wrote in post #4934499 (external link)
precisely;):D
As you say, we would presume there would be some small drain when not shut off properly, I wndered whether anyone else had noticed a complete drain though? Also the batery might not have had a ful charge when I finished with it, but I do know I hadn't used it much with this battery and that this was one of the Canon batteries
steved110 wrote in post #4935252 (external link)
a couple of the batteries are about 18 months old a couple about 12 months
Generally I don't leave the camera on when not using it but obviously as Im asking I occasionally either forget to turn it off or it gets rubbed inside the bag and turns back on itself .
Im not sure if this happens consistently but as this is not the first time I have noticed it, I thought I d find out what other's experience was of battery life when left on auto off, rather than when swithched off properly
[actually the on/off switch is something I d like to see ina different position for the next version as it turns on and off frequently if walking with it hanging ona strap and rubbing on the body]
Veni, Vidi, Snappi
Jon
Joined Jun 2004
Feb 17, 2008 17:13 |  #11
I don't believe that turning the camera "off" does anything much but disable the controls. You'll notice that if you insert a card, for instance, when the camera's off the card activity light still kicks in.
Jon
Cocker Spaniels
I ­ Simonius
Gallery: 19 photos
Feb 17, 2008 17:19 |  #12
Jon wrote in post #4936794 (external link)
good point - so Im still left wondering whether this si normal to see a dud battery after being left on auto off, or not
For the amount I use the batteries I don't think they should be dying yet:eek: - the charger appears to work OK
Veni, Vidi, Snappi
twotimer
Feb 17, 2008 18:59 |  #13
I rarely turn the camera off and the charge seems good for at least a month or 1,000 exposures which ever comes first.
Gerhard
silvex
Gallery: 21 photos
Feb 17, 2008 19:38 |  #14
my 30D with 2650 rechargeable AA batteries does not seem to disrchage them by much if any. Same goes for the 580ex2.
-Ed
CPS Platinum Member.
Canon Gear
SilvexPhoto.comexternal link
sapearl
Gallery: 243 photos
Feb 17, 2008 19:38 |  #15
Typically when you charge Simonius, how long on average do you leave the battery in the charger as it charges?
I Simonius wrote in post #4936821 (external link)
.....For the amount I use the batteries I don't think they should be dying yet:eek: - the charger appears to work OK
3,664 views & 0 likes for this thread, 13 members have posted to it.
1690 guests, 140 members online
