I'm just wondering if hotspots are an issue with camera bodies that are modified for IR or if they're only an issue if you're doing long exposures with a filter. Thanks.
Dave
forsakenme720 Senior Member 910 posts Joined Mar 2006 More info | Feb 17, 2008 19:02 | #1 I'm just wondering if hotspots are an issue with camera bodies that are modified for IR or if they're only an issue if you're doing long exposures with a filter. Thanks. Cameras: Canon 20D, Canon Rebel XT (converted to infrared)
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Feb 17, 2008 21:14 | #2 Same question here... I have been thinking about IR modding a 20D or XT... [Gear List | Flickr
Mark_Cohran Cream of the Crop More info | Feb 17, 2008 22:56 | #3 As far as I can tell from my research, the IR Hotspots are lens dependent. By that, I mean, it doesn't matter if you're using a converted camera or a filter, the lens is the critical element for IR hot spots. There's a list of good/bad lens for IR around here somewhere if you do a search. Mark
Feb 18, 2008 08:16 | #4 Mark_Cohran wrote in post #4938753 As far as I can tell from my research, the IR Hotspots are lens dependent. By that, I mean, it doesn't matter if you're using a converted camera or a filter, the lens is the critical element for IR hot spots. There's a list of good/bad lens for IR around here somewhere if you do a search. Now, if I'm wrong, I hope an IR expert will speak up and correct me. Yeah, I know it's dependent on the lens. The only thing is, I've never heard anyone complaining about hotspots with their converted bodies, only when using filters. This led me to believe that the long exposures are what was causing the hotspots with the particular lenses. It's just a guess, but it makes sense to me. So if anyone that has a converted body can comment... Cameras: Canon 20D, Canon Rebel XT (converted to infrared)
gasrocks Cream of the Crop 13,432 posts Likes: 2 Joined Mar 2005 Location: Portage, Wisconsin USA More info | Feb 18, 2008 11:28 | #5 http://www.naturfotograf.com/lens_surv.html#top1 GEAR LIST
tiktaalik Goldmember 1,213 posts Joined Feb 2006 Location: Southern California More info | Feb 18, 2008 11:50 | #6 I took this shot with a modified 10D and a 16-35.
The 16-35 is on the "not suitable for IR" list yet in my very brief testing I see no hotspots. On the other hand, when I was using a filter for IR my 28-135, which is on the 'suitable for IR' list, gave me a very ugly hotspot. I do think that some lenses are better than others for IR but that a modified body, with its shorter exposure times, is much more forgiving of a 'bad' lens. Julie
Feb 18, 2008 11:56 | #7 tiktaalik wrote in post #4941797 I do think that some lenses are better than others for IR but that a modified body, with its shorter exposure times, is much more forgiving of a 'bad' lens. That's exactly what I was thinking. Thanks for giving me your experience with it. I really appreciate it. Cameras: Canon 20D, Canon Rebel XT (converted to infrared)
| Latest registered member is semonsters 1556 guests, 135 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
