Ok an update for you dean and anyone else following this. I called the local camera shop about those F1000 suction cups, they are back ordered from Manfrotto and don't know when they will get them in. I am not sure what to do since I am leaving next week.
I got a 3/4 inch pipe to go over the suction cup stud. I got a couple more metal clamps to strengthen up the channel guide I have chosen to go with over a metal pipe.
I can see that I have a ton of sideways play that I am trying to get rid of. I used, temporarily, a rope stretched tight hooked to the bottom of the magic arm. The sideways play is not as bad with the rope attached. I am going to get some cable and see how much better it works over the rope.
| Byte size: ZERO | Content warning: NOT AN IMAGE |
Showing play from side to side without the rope.
1.
2.
Seeing how the images should turn out.
Comments, crituqes, and helpful hints are welcome.
