took my first moon shot tonight, my first attempts came out very very bright but i figured out that if you use a shutter speed of 1/500 you can get much better results.
![]() | HTTP response: 502 | MIME changed to 'text/html' |
fredmitcham Member 219 posts Joined Jan 2007 More info | Feb 19, 2008 01:05 | #1 Permanent bantook my first moon shot tonight, my first attempts came out very very bright but i figured out that if you use a shutter speed of 1/500 you can get much better results.
JuSlaughter Goldmember 1,082 posts Likes: 7 Joined Aug 2006 Location: Worcester, UK More info | Feb 19, 2008 01:31 | #2 Fred, welcome to the forum. If you take a look at some of the other moon shots that have been posted recently, many supply the ideal settings for taking moon shots. Canon 7D2, Canon 5DC, Canon 40D, Canon 350D, 17-40mm F4, 24-105mm F4, 50mm F1.8, 100mm F2.8, 300mm F4, 70-200mm F4 IS, 100-400mm f5.6, Sigma 15mm Fisheye, Sigma 10-20mm F5.6, 580EX II, 430 EX and a bagload of other stuff
muscleflex Goldmember 3,013 posts Likes: 3 Joined Jun 2005 Location: UK More info | Feb 19, 2008 03:13 | #3 what lens did you use?
sharma_AJ Junior Member 24 posts Joined Feb 2008 More info | Hi,
got this shot with my Rebel XTI 70-300mm Tripod Mounted with Mirror Lockup and remote shutter release. Canon 90D, Canon 50D with Grip, Rebel XTI with Grip, 70-300 IS USM, Canon 17-85mm IS USM, Canon 50mm 1.8, EW-73B Lens Hood, Speedlite 430ex, RS-60E3 Shutter Release, LowePro Minitrekker AW, LowePro Vertex 300, Manfrotto 055XPROB/488RC2 Head
Feb 20, 2008 11:17 | #6 Permanent banthose are a little better i guess but i think they could be even better if you used a shutter of 1/500
Badger49456 Senior Member 421 posts Likes: 32 Joined Jan 2008 Location: Midwest More info | Feb 20, 2008 12:18 | #7 Fred, you don't need to use 1/500. I'm not sure how your camera operates, but try using an ISO of 100, f/11 and 1/160... a tripod and using the timer will help a lot.
andrewhuxman Cream of the Crop 8,601 posts Likes: 4330 Joined May 2005 Location: Rockford Illinois More info | Feb 20, 2008 17:25 | #8 Here is a shot that I took in January , Manual focus , Mirror Lock Up, Remote shutter release maybe this info can help you on your next attempt. A little L goes a long way.
| Latest registered member is Frankie Frankenberry 1093 guests, 119 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
