Thread started 19 Feb 2008 (Tuesday) 09:30
Moving from USB 2.0 to firewire 800
cosworth
I'm comfortable with my masculinity
Feb 19, 2008 09:30 |  #1
When it comes to external hard drives, have any of you noticed a significant performance increase in read/write speeds moving from a USB 2.0 to Firewire 800 enclosure?
It's about $100 for en express card, another $150 to source the Firewire 800 RAID enclosure I want. I am not sure the cost can justify the performance increase since I'm not noticing it much now. Lightroom can slow a bit but I have a massive catalogue.
Anyone that feels they get 10 horse from an oil change in their car need not reply. ;)
people will always try to stop you doing the right thing if it is unconventional
Full frame and some primes.
danpass
Feb 19, 2008 09:30 |  #2
I wonder if a SATA enclosure would be your ticket.
eta:
It says Sata 2.0 (3 Gb/s)
http://www.newegg.com …aspx?Item=N82E1​6817121913 (external link)
Dan
Gallery (external link) | Gear/Feedback
silvex
Gallery: 21 photos
Feb 19, 2008 10:43 |  #3
Yeah I would go with SATA HW RAID card too -- I have one in my Linux server. Get the PCIe cards if your MOBO supports. PCI-X cards work in PCI slots but at a reduced speed. I would also stick with well know brands such as: Adaptec, 3Ware or LSI. They are a but pricey $300+ but have the HW RAID and 64MB+ buffers. Some I think have 256MB buffer.
-Ed
CPS Platinum Member.
Canon Gear
SilvexPhoto.comexternal link
cdifoto
Don't get pissy with me
Feb 19, 2008 10:47 |  #4
I didn't do firewire but I went from USB to eSATA and I've been back to USB since the ExpressCard adapter took a dump on me. I thought I noticed an improvement with the eSATA at first but in daily usage, I don't see problems plus I have access to my headphone jack again. The USB tethered external is my working storage drive. I access it regularly throughout a given day.
cosworth
Feb 19, 2008 11:36 |  #5
I wasn't clear enough. I have a laptop with a mini expresscard. eSATA cards are available for $25 easy. External dives with eSATA are easy to find, but a raid array is a bit more of a search. Up to 3 times the speed is nice.
I'd like this enclosure:
http://www.ncix.com …merican%20Media​%20Systems (external link)
Add a $25 34mm mini expresscard eSATA.
Ok I'm stoked now. And I now see that Transcend's 16gb mini expresscard Solid State Drive is $110 now. I'm sure CS3 would see it as a nice fast scratch disk, but I'd have to unplug my external drive and plug it into the USB port.
Excellent answers guys.
cosworth
Feb 22, 2008 15:16 |  #6
So I bought that enclosure and a 34mm eSata II expresscard (3 Gpbs!!!!!).
I have 2 Seagate barracudas @ 7200 rpm. I have two partitions each for 4 drive letters. all the same size. 450, 450, 50, 50. The two 50gb partitions are on different drives. I will have my scratch disk on one and my OS swap file on the other. This frees up my OS drive and delegates the two 7200 rpm drives to handle massive memory swap. That with my 4gb of RAM should make my XPs pretty quick for post processing.
I decided against raid and will back between the two 450 partitions. Once my images fill the 450 partitions, I can move up from there to 1tb drives. This solves the laptop hard drive restriction quite handily. eSata II is incredibly fast.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Feb 22, 2008 15:27 |  #7
Amazing, you are getting full desktop drive performance in a laptop now?
Wow..
CDS' HOT LINKS
cosworth
Feb 22, 2008 15:39 |  #8
Yep. I have 3 7200rpm drives running now. I can upgrade to 10000 rpm if I so choose now.
eSata II is the new black. Firewire = slow. USB 2.0 = buh bye.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Feb 22, 2008 15:42 |  #9
I wonder if my aged notebook can handle a full speed esata card.. likely not. It has no "expresscard" that's certain. Maybe Cardbus.
CDS' HOT LINKS
cosworth
Feb 22, 2008 15:45 |  #10
PCMCIA sata II at 3Gbps.
http://www.satacard.co​m/pc112.html (external link)
danpass
Feb 22, 2008 15:51 |  #11
Dan
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Feb 22, 2008 15:53 |  #12
I just looked up the speeds on the specs, and Cardbus would only take a minor hit over the SATA interface, and since drives aren't that fast anyway, even cardbus would mean pretty much full speed.
Cardbus runs at a maximum speed of 133Megabytes/sec.
SATA runs at a maximum speed of 150Megabytes/sec. (doubled to 300 with SATA II 3G )
PATA runs at a maximum speed of 133Megabytes/sec.
FireWire800 runs at a maximum speed of 100Megabytes/sec.
CDS' HOT LINKS
cosworth
Feb 22, 2008 15:53 |  #13
danpass ftw.
danpass
Feb 22, 2008 16:00 |  #14
cosworth wrote in post #4973656 (external link)
danpass ftw.
lol
Dan
silvex
Gallery: 21 photos
Feb 22, 2008 16:06 |  #15
cosworth wrote in post #4973408 (external link)
Have you try turning off virtual memory completely? My PC has 4GB with virtual memory off. I also have the /PAE switch and runs MUCH better. It already had the /3GB switch but for some reason the /PAE made a world of difference.
-Ed
Canon Gear
2,498 views & 0 likes for this thread, 6 members have posted to it.
1709 guests, 141 members online
