Thread started 19 Feb 2008 (Tuesday) 10:50
580 EX II Newbie Question!
nicolasonline
Feb 19, 2008 10:50 |  #1
The 580 EX II Ratio mode only works in ETTLII right? In other words if you set a ratio, it's all relatively based on what exposure ETTL determines for you? So in Manual mode, there is no "ratio" there is only what you set for each flash correct?
Canon EOS 5D Mark II - EF 24-105 f4 L - EF 50 f1.4 - EF 100 f2.8 Macro -  MacBook Pro
Curtis ­ N
Master Flasher
Feb 19, 2008 11:02 |  #2
You got it.
PacAce
Joined Feb 2003
Feb 19, 2008 11:09 |  #3
nicolasonline wrote in post #4948982 (external link)
Well, not necessarily. If you are controlling the power output of the slaves from the master (where the master is in Manual mode), the only way to do that is by using the Ratio feature.
...Leo
nicolasonline
Feb 19, 2008 12:06 as a reply to  @ PacAce's post |  #4
So basically on the ST-E2 when it's set to ratio, you don't fully control your slaves unless you set the ratio on the slave. But what happens if on the ST-E2 you set the ratio to 3:1 and you set a different manual setting on each slave?
PacAce
Joined Feb 2003
Feb 19, 2008 13:01 |  #5
nicolasonline wrote in post #4949479 (external link)
The ST-E2 can only control the slaves in ETTL mode so, since it can't do manual, whatever I posted in my previous post does not apply to the ST-E2. If the slaves are set to ETTL mode also, the ST-E2 will control the ratios. But if the slaves are in manual mode, whatever power the slave are manually set to is what they'll fire at. And this is true even if the master is a flash like the 580EX.
...Leo
nicolasonline
Feb 19, 2008 13:13 as a reply to  @ PacAce's post |  #6
Thank you so much for your help!
Tom ­ Camilleri
Joined Jan 2005
Feb 19, 2008 17:03 |  #7
PacAce wrote in post #4949102 (external link)
Don't want to hijack the thread but I have a similar question. For manual and with 2 units can I have the master off camera, connected by a PC cord and have the master control the slave?
40D, Digital Rebel 300D; EF-S 17-55 f/2.8 IS, EF 28-135 IS, EF 50mm f/2.5 Compact Macro, 85mm f/1.8, 28mm f/1.8, Speedlite 380 EX, Sekonic L758DR w/target, Manfrotto 3021 w/3030 pan-tilt head & quick release plate, POTN Strap
PacAce
Joined Feb 2003
Feb 19, 2008 17:29 |  #8
Tom Camilleri wrote in post #4951680 (external link)
Yes, you can but you have to make sure that the master is in Manual mode.
...Leo
joruiz
Feb 19, 2008 18:14 |  #9
That's what I do, but instead of a PC cord I use the cheap ebay trigger to trigger the 580EXII, which in turn triggers the 430EX slave. 580 must be in manual mode as pacAce said..
Cantisani
my facebook profile (external link) |
Tom ­ Camilleri
Joined Jan 2005
Feb 19, 2008 19:34 |  #10
joruiz wrote in post #4952215 (external link)
Thanks. The trigger is an option I hadn't considered but might be more convenient than cord.
Tom ­ Camilleri
Joined Jan 2005
Feb 19, 2008 19:35 |  #11
PacAce wrote in post #4951865 (external link)
This is just what I was hoping to do. Thanks for response.
Polekat
Feb 19, 2008 20:06 |  #12
My shiny new 580 EX II arrived today. A little gift for myself paid for by my tax return. Anyway, at first glance it looks like you need a masters degree to use the thing. :-(
Just learning the ropes. My equipment:
Canon Digital Rebel XTi
50mm f/1.8, Canon 70-200L f/4
580 EXII
Tom ­ Camilleri
Joined Jan 2005
Feb 20, 2008 01:03 |  #13
Can the master and slave be manually fired together from the master unit so output can be metered?
Lotto
Feb 20, 2008 03:33 |  #14
Tom Camilleri wrote in post #4954793 (external link)
Yes they can if the master unit is also in manual mode.
5D, 24-105L, 70-200L IS, 85mm Art, Godox
PacAce
Joined Feb 2003
Feb 20, 2008 08:46 |  #15
Lotto wrote in post #4955193 (external link)
Forgot to mention this earlier but be sure to set the shutter speed on the camera and the meter to 1/125 or slower if using a PC cord or even a wireless trigger.
...Leo
2,511 views & 0 likes for this thread, 7 members have posted to it.
862 guests, 147 members online
