I LOVE my 24-70. Unfortunately there seems to be a grain of sand underneath my focus ring which makes an unhealthy sound with Manual Focus. As I turn the ring it sounds like I am rubbing sand paper. What can/should I do?
TitusvilleSurfer Senior Member 784 posts Joined Nov 2007 Location: Titusville, FL More info | Feb 19, 2008 23:04 | #1 I LOVE my 24-70. Unfortunately there seems to be a grain of sand underneath my focus ring which makes an unhealthy sound with Manual Focus. As I turn the ring it sounds like I am rubbing sand paper. What can/should I do? 50D | G11 | 50mm f/1.4 | 70-200 f/2.8 IS | 580exII
sheawyatt Goldmember 1,412 posts Likes: 30 Joined Dec 2005 Location: Victoria, BC More info | Feb 19, 2008 23:14 | #2 I had the same thing with my 17-40 after I was at the beach one day - it went away after a while (hopefully the sand fell out and not into the lens). I got some more in it, and after closer inspection, it looked like it was actually sand between the edge of the focus ring and the body of the lens - a toothbrush cleaned most of it out, maybe give that a shot around the edges? EOS R5 | RF 15-35 f/2.8 | RF 24-70 f/2.8 | RF 70-200 f/4 | EF 400 f/4 DO II | EF 1.4x III |
TitusvilleSurfer THREAD STARTER Senior Member 784 posts Joined Nov 2007 Location: Titusville, FL More info | Feb 19, 2008 23:30 | #3 On a brighter note, I also had 3 pieces of dust noticeable against the blue sky in my shots. I placed the camera on my kitchen counter and ran "sensor cleaning" 10 times...it took about 1 minute. Zero dust specs are now visible. 50D | G11 | 50mm f/1.4 | 70-200 f/2.8 IS | 580exII
DoubleNegative *sniffles* 10,533 posts Likes: 11 Joined Mar 2006 Location: New York, USA More info | Feb 20, 2008 08:38 | #4 I had that happen to my 35mm f/2... I had it serviced, as it prevented the focus mechanism from operating properly. La Vida Leica!
gasrocks Cream of the Crop 13,432 posts Likes: 2 Joined Mar 2005 Location: Portage, Wisconsin USA More info | Feb 20, 2008 09:05 | #5 Have you tried holding a vacuum cleaner hose next to the focus ring while you turn it? GEAR LIST
| Latest registered member is MWCarlsson 703 guests, 128 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
