Thread started 19 Feb 2008 (Tuesday) 23:14
skiing: motion blur at 1/1600th?
matthew ­ blake
Feb 19, 2008 23:14 |  #1
how is it possible that shooting at 1/1600th of second exposure i was still getting blurry subjects?
http://img214.imagesha​ck.us/img214/2771/img8​375tc9.jpg (external link)
sigma 50-500 at 500mm, iso 200, f8, 1/1000th, tripod
http://img515.imagesha​ck.us/img515/8610/img8​364vx5.jpg (external link)
sigma 50-500 at 500mm, iso 200, f6.3, 1/1600th, tripod
mattograph
"God bless the new meds"
Feb 19, 2008 23:16 |  #2
Drinking too much Toddy?
Giddy with Anticipation?
Actually, this has happened to me in AI Servo before. The camera will fire without AF confirmation.
Nice lens, BTW.
This space for rent.
matthew ­ blake
Feb 19, 2008 23:25 |  #3
i didn't understand any of that, these were pre-focused, the snow around the skier looks to be in focus to me.. so why is the skier blurry? they're going fast but not that fast..
sugarzebra
Feb 19, 2008 23:39 |  #4
I think it is because they are going so fast....I haven't double checked the math but I think at 70 mph the skier travels about 0.8 of an inch in 1/1600 sec.
The slight blur does give the impression of speed which helps the feeling of the shot, so the small amount of blur in these two shots doesn't hurt the shot at all.
Scott
Website & Blog (external link)
mattograph
Feb 19, 2008 23:46 |  #5
matthew blake wrote in post #4954411 (external link)
My theory is all wet if they were focused manually. Perhaps panning next time (if you didn't on these).
The shots look good though. Nice, clean composition, and the slight blur doesn't bother me at all.
matthew ­ blake
Feb 20, 2008 00:01 |  #6
sorry i mixed those up, the first link is at 1/1600th, the second is at 1/1000th. panning definitely wasn't an option at 500mm and the speeds they were going, that would take some serious skill. i was also surprised at how hard it was to get the skier between the two gates even with 5fps, those were the only two that worked out from about ten skiers that i shot from that position. i have a couple shots taken more head on and they're not nearly as blurry. in any case now i know why things like 10fps bodies and 500mm f4 lenses exist. i regret not trying at 1/3200 iso 400.
AdamLewis
Feb 20, 2008 13:11 |  #7
Without knowing anything about skiing..
If the snow around them is in focus, then obviously they ARE going "that fast" haha. Turn up your shutter speed.
JohnJ80
Feb 20, 2008 14:20 |  #8
IIRC, the lens you are using isn't HSM (like canon's USM). If it isn't ultrasonic motor, it won't be able to focus fast enough - won't even have a chance. If not USM, then what you have to do is prefocus on a spot and shoot when the skier gets there.
If you have done all that, then it is speed. I would say that 1/1600s is bare min for speed anyhow. Go faster if you can. However, i suspect it is the USM issue.
I shoot a fair amount of skiing, and there are others here that are way into it (Primoz, for example). It is a tough application and one that Canon specifically talks about in their documentation as being difficult due to speed.
Looks like Super-G to me, so they won't be going 70mph (average), but they are going fast (50's or so).
Which body are you using? 20D, 30D are going to have AF difficulties with this. 40D is going to do better, but 1DMk2 or Mk3 is probably the ticket.
J.
Obsessive Gear List
"It isn't what you don't know that gets you in trouble; it's what you know for sure that isn't so." - Mark Twain
matthew ­ blake
Feb 20, 2008 14:52 |  #9
JohnJ80 wrote in post #4958356 (external link)
J.
its downhill, using a 30d and like i said in another post i used a tripod and prefocused and waited. i guess it just never occured to me that you could get motion blur at 1/1600th of a second, how fast would i have had to go?
FlyingPhotog
Cream of the "Prop"
Feb 20, 2008 15:00 |  #10
Most of the best skiing shots I've seen are usually taken looking up the hill...
Try not shooting perpendicular to the action:
http://www.myplanet.ne​t/csharp/TEDWINTERPARK​4X6.jpg (external link)
Jay
tomd
Feb 20, 2008 15:08 |  #11
Like said above ^^^, try not to shoot perpendicular to the skiier.
Also, search for Primoz, here on this forum. He is the best ski photo around. He has given a ton of advice on situations like yours.
Tom
=======>>> play W.A.I.N. :D
JohnJ80
Feb 20, 2008 15:18 |  #12
matthew blake wrote in post #4958599 (external link)
Well then it is motion blur.
Probably go as fast as your camera can.
J.
Obsessive Gear List
primoz
POTN Sports Photographer of the year 2005
Joined Dec 2004
Feb 20, 2008 15:43 |  #13
If this is current Whistler, then it's downhill. If it's downhill then yes they are fast. Normal speed on downhill is above 100km/h, and it can easily reach up to 130 or 140km/h. Based on skiers position and snow from under the skis, they are at least at 100km/h. Ok now it's a bit late, but if I calculated right, they move for about 5cm at 1/1000sec. So when going across frame, 5cm is enough for motion blur.
As someone suggested already, go with panning. It's not panning in real meaning of word, but you still follow skier and compensate for those few centimeters. And such thing can be easily done with 500mm lens ;)
i was also surprised at how hard it was to get the skier between the two gates even with 5fps, those were the only two that worked out from about ten skiers that i shot from that position. in any case now i know why things like 10fps bodies and 500mm f4 lenses exist. i regret not trying at 1/3200 iso 400.
You would be surprised to know I would shoot your photo with single frame and way bellow 1/2000sec ;) As I wrote before... tracking skier is way to go, and you are fine with 1/800 or even slower. As far as high fps goes. It still doesn't help ;) This (external link) is what 8.5fps does. And it's way too slow for perfect timing (external link). So it's not about camera and high fps, but photographer ;)
PhotoSI (external link) | Latest sport photos (external link)http://www.photo.si (external link)
matthew ­ blake
Feb 20, 2008 16:25 as a reply to  @ primoz's post |  #14
i guess panning is the answer, i don't know how you can pan a tight shot like that with someone going 100kph, definitely a skill i don't possess :)
do you have any examples of this?
Shadiow
Feb 20, 2008 16:40 |  #15
primoz wrote in post #4958945 (external link)
And after looking at this guys photo's... Holy F. I would listen to him.
::A|S::Shadiow::
::Gear::
3,814 views & 0 likes for this thread, 17 members have posted to it.
1049 guests, 116 members online
