Thread started 18 Oct 2004 (Monday) 03:20
Purple haze.
dewmuw
Joined Jul 2002
Oct 18, 2004 03:20 |  #1
Ok - so I took this last week and wanted to show off the sky. I selected the sky and did a bit of post processing to highlight the moodiness.
However, I ended up with a 'fringe' around the tail. How do I eliminate this?
Damian Waters
www.drumimages.co.uk (external link)
J___
Joined Aug 2003
Oct 18, 2004 05:33 |  #2
burn tool in photoshop?
what is that caused by? the lense? do u use the new DO?
Canon EOS 310D | 18-55mm | 24-85mm F3.5-4.5 USM | 50mm 1.8
Canon Powershot A70 | fisheye+macro combo lens | Canon 2.4x Telephoto
www.zalproductions.com (external link)
Radtech1
Everlasting Gobstopper
Joined Jun 2003
Oct 18, 2004 06:13 |  #3
What postprocessing did you do?
Be humble, for you are made of the earth. Be noble, for you are made of the stars.
dewmuw
Joined Jul 2002
Oct 18, 2004 07:08 |  #4
I selected the sky and then adjusted curves.
I don't know what causes the haze - I assumed it was as a result of the processing.
Damian Waters
J___
Joined Aug 2003
Oct 18, 2004 07:28 |  #5
that would de it. u probably left some bit of the sky around the tail when u adjusted curves unselected
PacAce
Joined Feb 2003
Oct 18, 2004 09:04 |  #6
Next time you make a selection, pay close attention to the value in the Feather box. You probably have it set to a relatively high number. What I would do in this case is use a feather of 0 or 1 since the lines on the plane are hard and hence doesn't really need any feathering. But you have to be exact in your selection.
...Leo
vfilby
Joined May 2004
Oct 18, 2004 09:14 |  #7
This probably doesn't apply but it is similar.
I often get halos when using blur creatively. What I do to avoid them is to select the background and copy it into a new layer. Then do a super quick job with the clone tool to fill in the blank area that was left by the subject. Now I can blur the background and I don't get the subject colour (or grey when I cut the subject and leave that area blank). Then I put the subject back in, maybe feathered slightly and there are no halos.
Speaking of Halo, Nov 9th is fast approaching.
Cheers,
Glass and plastic
1,664 views & 0 likes for this thread, 5 members have posted to it.
Purple haze.
2035 guests, 99 members online
