Thread started 20 Feb 2008 (Wednesday) 11:37
quick ACR question
matthew ­ blake
Feb 20, 2008 11:37 |  #1
If I increase blacks in ACR, or decrease darks in the curves tab, it seems to do exactly the same thing, does it? also, is it possible to get curves in photoshop like you can in ACR where you can just use sliders for 'highlights, lights, darks, shadows', instead of having to manipulate the actual curve? (which i find much more difficult and don't like how lowering one thing raises another).
thanks
Longwatcher
obsolete as of this post
Joined Sep 2002
Feb 20, 2008 15:16 |  #2
Guessing here;
I think the slider for blacks in ACR is setting a cutoff point where everything below that point will be black and then it adjusts the scale for the rest, while the curve slider is adding/subtracting values to pixels. It may have the same effect, but getting to it from a different direction.
Or they may be the same thing, just different tools.
"Save the model, Save the camera, The Photographer can be repaired"
www.longwatcher.com (external link)
1DsMkIII as primary camera with f2.8L zooms and the 85L
http://www.longwatcher​.com/photoequipment.ht​m (external link)
René ­ Damkot
Feb 21, 2008 04:26 |  #3
Longwatcher guessed correct :)
Increasing the blacks will clip them. The curve will work a bit more 'gradually'.
In PS you can make a curves adjustment layer, then Cmd (Ctrl?) click in the image, this will give you an 'anchor point' on the curve on the value you clicked. You can then use the arrow keys (or mouse) tho move them
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
902 views & 0 likes for this thread, 3 members have posted to it.
quick ACR question
1049 guests, 115 members online
