Ok so I was reading the "Bible" tonight, I was confused by the motion blur, because I was under the assuption that flash photo's weren't affected by Shutter speed. But if I interpreted the "Bible" correctly, the fact that I was shooting in Av means that I meatured for the ambient light, and the camera will set the shutter speed for low light as it would without the flash. (just adding fill) is that correct? So when it is darkish, I should switch to P? (or M when I've read the "Bible" a little more thoroughly)
