Thread started 23 Feb 2008 (Saturday) 16:34
emulating picture styles on the 20D?
gregjp48
Feb 23, 2008 16:34 |  #1
what parameter settings can you use on the 20D to mimic picture styles?
Camera Gear: [20D][Tamron 28-75][Sigma 10-20] [Canon 50 f/1.8 mk II][Canon FL 50 f/1.8][Canon FD 135 f/2]
[IBook G4 1.33ghz 1GB Ram][60GB Hardrive][160gb Seagate FreeAgent]
My flickr (external link)
tzalman
Fatal attraction.
Feb 23, 2008 17:11 |  #2
You can't really, because beyond changes in contrast, saturation and sharpness (which you can change in the jpg parameters) Picture Styles also have unique color relationships. For instance, Landscape boosts blues and greens, but without altering the WB. Autumn emphasizes yellows, oranges and reds. The three Portrait styles boost red in differing degrees. Faithful is colormetrically accurate for sunlight.
What you can do is to shoot Raw and apply the Picture Styles in DPP.
Elie / אלי
gregjp48
Feb 23, 2008 17:20 |  #3
so the only way would be to boost saturation in specific colors in LR after the fact?
Raw isn't really an option for me (speed of computer/ hard drive space, all that fun stuff).
But I guess I'll just set all my sharpness to +1, and have varying degrees of contrast and saturation for different subjects as far as parameters go.
Then I'll PP later to get my desired effect I guess.
Do you actually use the Picture Styles on whatever camera? I saw them in Canon's brochure and they intrigued me.
I wonder why Canon didn't just offer a firmware update for the 20D with pic styles on it...
nicksan
Man I Like to Fart
Feb 23, 2008 21:34 as a reply to  @ gregjp48's post |  #4
If you use DPP, then you can actually apply the typical Picture Styles there.
Doug ­ Pardee
Feb 23, 2008 23:25 |  #5
gregjp48 wrote in post #4979670 (external link)
Canon doesn't do that. They put out a new camera model instead. For example, picture styles was one of the big differences between the 1DmkII and the 1DmkIIN. In the case of the 20D, they came out with the 30D.
Canon has never provided a firmware update to any DSLR where the update added new features, aside from rare updates to allow new hardware to be used with a current camera model (such as the update to allow the WFT to be used with the 20D).
gooble
Feb 24, 2008 01:08 |  #6
Have you tried handling RAW files on your computer? What are your specs?
kevin_c
Feb 24, 2008 06:11 |  #7
nicksan wrote in post #4981125 (external link)
Thats my advice - Shoot RAW and just select the style you want from the drop-down menu in DPP and job done.
Or - You could always get a new 40D and do it in-camera... :)
-- K e v i n --
Nikon D700, 17-35mm, 28-105mm, 70-200mmVR, 50mm f/1.4
Canon EOS 3, 24-105L, 135L
gregjp48
Feb 24, 2008 20:41 |  #8
ibook G4 12" 1.33Ghz with a gig of ram
I mean with Lightroom of course. I could probably set them up to process overnight or something, but it would be laggy using lightroom, and I have a 55GB hard drive, not something to use for raw.
I'd buy a new computer, but lenses are far more important to me at the moment, especially since I just broke the autofocus on my kit lens by dropping it.
gooble
Feb 24, 2008 23:43 |  #9
gregjp48 wrote in post #4987640 (external link)
Have you tried using DPP on your laptop. It is not nearly as processor intensive as Lightroom. What processing are you talking about? If you want to apply Styles to all pictures of a shoot it takes about 10 seconds.
gregjp48
Feb 28, 2008 22:16 |  #10
no what i mean is the only raw workflow I could think of using would be a lightroom non destructive one due to hd space constraints, and my laptop just isn't powerful enough to work with the raw files using lightroom anyway.
Having tiffs on my hd would be a lot harder than jpegs, and I don't see the benefit of raw that would cause me to buy new hard drives rather than lenses (my budget is fairly tight)
2,062 views & 0 likes for this thread, 6 members have posted to it.
1143 guests, 171 members online
