On the 5D, the 24-70, 70-200, and 1.4X telecon make a great combination. But you don't have a 5D in your lineup.
What I suggest is this - go out around your own town with the 24-85 and 70-200 and see if 24 mm is wide enough on your Mk III. If so, then the 24-70 (or 24-105 if you prefer) and 70-200 would be the right combination. If not, then you'll have to use the 16-35, 70-200, and possibly a 50/1.4 to fill out the middle (and give you a low-light lens).
Now, if you're taking the 10D instead of the 1D3, then 24 mm isn't going to cut it, and since it doesn't fit EF-S lenses, you would probably want to consider one of the APS-C f/2.8 zooms from Sigma or Tamron (17-50 or whatever) to carry along with your 70-200.
Now, I won't go into depth concerning choosing the 24-70 or 24-105. I prefer the 24-70 due to less corner light falloff wide open, less barrel distortion at the wide end, and smoother bokeh. However, the 24-105 is no slouch and it does present IS which is quite useful when lighting gets low. Both are good lenses IMHO.
