Thread started 25 Feb 2008 (Monday) 19:06
40D - EC info when shooting in Manual
MJH1
Feb 25, 2008 19:06 |  #1
I just took some shots with my 40D in manual exposure mode with my 580EX II. I was using the 40D to indirectly set my camera exposure compensation to -2 for the background (via adjusting ISO, speed and aperture) and my flash exposure compensation to -1 for filling a backlit portrait (late day sun). I then checked the image info on the 40D LCD and was surprised to see the camera EC was not recorded there. Damn. :mad:
When shooting Av mode, both ECs info is captured. I was trying several combinations of camera EC and FEC and wanted to review the photos with both these factors in mind, but can't since camera EC is apparently not recorded when in manual - unless some genius here can tell me a way! Would greatly appreciate the help. :D
Mike
Mark_Cohran
Joined Jul 2002
Feb 25, 2008 19:10 |  #2
EC isn't recorded in manual mode because you're not really setting exposure compensation, but rather you're directly setting the exposure.
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Forty years of shooting and still learning.
My Twitter (external link) (NSFW)
Follow Me on Instagram (external link)
Kevin
Feb 25, 2008 19:12 |  #3
In manual mode when you under or overexpose from zero you are doing just that. In AV and TV mode when you set an EV valve you are overriding the cameras meter reading.
MJH1
Feb 25, 2008 19:17 as a reply to  @ Mark_Cohran's post |  #4
Thanks Mark. We're talking about the same thing, but stating it a little differently I believe. IMO when in Av, I am directly setting camera EC by adjusting the EC display (and the camera adjusts the variable(s) to get me the EC I chose). When in Manual, I directly adjust ISO, shutter speed and aperture to indirectly adjust camera EC.
As mentioned, I'm shooting combinations of EC and FEC, then viewing the images to learn from them so I can begin to develop a gut-feel for settings I prefer under similar ambient light circumstances in the future. The absence of recorded EC really hurts. Are you sure that there is no way to obtain that info?
Mike
EOS_JD
Feb 25, 2008 19:20 |  #5
MJH1 wrote in post #4994522 (external link)
Mike
In Av or Tv if you use EC you are directly amending the camera's exposure. This would be the same in manual mode as far as I can see. AFAIK there is no such thing as EC in manual mode although the camera meter will give its indication, you manually over/under expose this for the given scene.
FEC is different as this adjusts the output of the flash at any given exposure.
All My Gear
5D MkIII & 5D MKII + Grips | 24-70 f2.8L IS | 24-105 f4L IS | 70-200 f2.8L IS MkII | 50 f/1.4 | 85 f1.8 | 100 f2.8 | 1.4x MkII | Tamron 17-35 f2.8-4
dekalbSTEEL
Feb 25, 2008 19:28 |  #6
You're going to have to get a 1-series body with the voice record function
Grippy 30D, Tokina 300f4, Sigma 18-50f2.8, Canon 70-200f4L, thrifty50mkI, PM7500DX
Jon Gee Photography.com (external link)
DDan
Feb 25, 2008 19:30 |  #7
EOS_JD wrote in post #4994533 (external link)
Yes. Saying that EC was set in MM is very confusing. I would stick to underexposing or overexposing to describe that.
DansRacePhotos.com (external link)
Dangerous Dan
MJH1
Feb 25, 2008 19:31 as a reply to  @ dekalbSTEEL's post |  #8
I'm amazed that this and better EOS DSLRs don't capture this info. Seems very fundamental. What a pain in the _ _ _.
Thanks everyone for your comments.
Mike
dekalbSTEEL
Feb 25, 2008 20:06 |  #9
When you're shooting in Manual, the SS and Aperture are recorded. Whether the needle in your viewfinder was to the left or to the right should be apparent in the captured image.
EOS_JD
Feb 26, 2008 11:52 |  #10
MJH1 wrote in post #4994588 (external link)
Mike
Not really sure why it would capture this info? Whaty is fundemental is that you get the exposure correct.
All My Gear
Jon
Joined Jun 2004
Feb 26, 2008 12:05 |  #11
Mike
There's a fundamental difference between how the camera sees an auto exposure with EC set and how it sees a manual exposure which you've set to under/overexpose from the suggested by a stop.
When you set EC, you tell the camera that "Everything I meter, no matter what the reading is, underexpose it 2 stops". So the camera has to remember "Hmmmm. . . 2 stops under. Right." and it has that info to record. It then applies that identical 2 stop adjustment to every shot you take until you reset EC.
When you use Manual mode, the camera doesn't even know if you used the in-camera meter to take a reading. You may have used the in-camera meter and offset "correct" exposure by 2 stops. But, you equally might have used a hand-held external meter to take an incident meter reading and set the aperture, shutter speed and ISO from that, disregarding the camera's meter. In addition, you might have set the aperture and shutter before taking one shot, then moved on to another shot without adjusting either of them for the new one. The meter may have showed 2 stops underexposure when you took the first shot but only 1 stop under, or 1 stop over, when you shot the second picture. What would "EC" mean there? Essentially, in Manual, the meter is disconnected from any active role in controlling your exposure.
Jon
Cocker Spaniels
EOS_JD
Feb 26, 2008 14:10 |  #12
Jon wrote in post #4999041 (external link)
Also remember that the camera meter is not an incident light meter. When using my studio strobes, the EC would be off the scale. My camera mater might tell me that the correct exposure is 2seconds at ISO100 and f8. However when I take my shot in the studio using manual, it's likely the real exposure is 1/125th @ ISO100 and f8.
As stated above there is NO EC in a manual exposure.
All My Gear
apersson850
Obviously it's a good thing
Gallery: 35 photos
Feb 26, 2008 15:19 as a reply to  @ EOS_JD's post |  #13
I understand the original poster wants a record of how the camera metered the scene, in spite of using manual mode.
But it's easy to accomplish. Set the camera to Av or Tv, then set an EC value you like and take the picture. The result would be the same as if you deviated from the metered value by using manual mode. But in this case, the EC is in the EXIF metadata.
Anders
MJH1
Feb 26, 2008 17:57 |  #14
apersson850 wrote in post #5000454 (external link)
Thanks Anders - you understand what I'm after and that's a good suggestion.
Mike
Perry ­ Ge
Batteries? We don't need no...   . . . or cards.
Gallery: 83 photos
Feb 26, 2008 18:10 |  #15
Sigh, this kind of thing comes up every once and a while when people have NO idea what M is for or how it's meant to be used. Everything Jon said is correct.
M is COMPLETELY different from Av, Tv, and P. The concept of EC has no meaning in M. M is the only mode in which you can set the exposure completely independently of the camera's meter. In every other mode the camera has some say, you don't have full creative control. You don't have to rely on your meter for exposures, y'know?
I don't remember the last time I looked at the camera's meter, or cared what its reading was during shooting, or in post.
The feature the OP cites would be completely useless imho. If you shoot in a studio, or do landscapes with GNDs, or are smarter than a reflected light meter that sees everything as 18% grey, why would you care how your camera metered the scene? It would serve no purpose. The camera is dumb, don't let it dictate your exposures.
Also, a lot of people, myself included, would not benefit from this feature. My exif would show all kinds of crazy sh** like EC + 8 and EC - 5 o_O...
??? Only if the light doesn't change, and you keep the camera on a tripod and perfectly still between both shots, and made an extra effort to get the exposures the same. But...why?
Perry | www.perryge.com (external link) | flickr (external link) | C&C always welcome | Market Feedback & Gear | Sharpening sticky | Perspective sticky
3,123 views & 0 likes for this thread, 11 members have posted to it.
1703 guests, 166 members online
