Thread started 21 Oct 2004 (Thursday) 20:59
EOS 1D Mark II owners with a Canon 70-200 F/2.8 IS.. help!!
JX
Joined Aug 2004
Oct 21, 2004 20:59 |  #1
Today I posted a thread called “My 70-200mm IS lens is buggy†it sparked a lively debate. The problem is when shooting in TV mode and low light levels my Canon EOS Mark II locks up and displays an err 01 code. This only happens when Image Stabilization is on. I would like to ask those members who have a Mark II and a Canon 70-200 F/2.8 IS UMS lens to take some test shoots. If you could use a low ISO speed and a very high shutter speed to force a failure. Does your Mark II lock up. If you would post your results I would appreciate it. I should have posted this question first.
Jim
JX
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Oct 21, 2004 21:29 |  #2
Jim,
I actually had this occur once as well.
I understand that by sending the lens to Canon they will update the IS motor and fix the problem.
Some say this lockup can occur on other bodies as well.. but it seems to be more likely on a MkII.
There is a thread on this somwhere on this forum wth a link to a post by Chuck Westfall of Canon that addresses the issue.
Hope this helps.
P.S. the immediate fix when it occurs in the feild is to simply power down, dsiconnect the lens ( hit the button and give it a simple twist.. no need to remove it all the way) and reinstall it.
CDS' HOT LINKS
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Oct 21, 2004 21:43 |  #3
P.S.
The gory details can be found here;
http://www.robgalbrait​h.com …iew=&sb=5&o=&fp​art=1&vc=1 (external link)
CDS' HOT LINKS
Mills
Joined Jul 2003
Oct 21, 2004 22:18 |  #4
I have yet to experience this problem.
Mills
1D Mark II & 5D
50 f1.4 16-35 f2.8L 24-70 f2.8L 70-200 f2.8L IS 580 EX & 550 EX Gitzo Mono & Tri Pods Apple iMac G5 & 17 Inch Powerbook
Box Alarm Images (external link)
http://www.myspace.com​/millz11 (external link) Just to see some fun camera phone stuff.:p
defordphoto
MKIII Aficionado
Joined Oct 2002
Oct 22, 2004 05:23 |  #5
I, also, have never had an issue with mine.
defordphoto | Celebrating the art of photography®
SD500, 10D, 20D, 30D, 5D, 1DMKII, 1DMKIII
www.ussbaracing.com (external link) | www.rfmsports.com (external link) | www.nwfjcc.com (external link)
An austere and pleasant poetry of the real. Ansel Adams
scottbergerphoto
Joined Jun 2003
Oct 22, 2004 05:48 |  #6
I have the non IS version. Glad I saved the $500.
Regards,
Scott
One World, One Voice Against Terror,
Best Regards,
Scott
ScottBergerPhotography (external link)
ssim
Joined Apr 2003
Oct 22, 2004 06:48 |  #7
I did do some tests with my MKII and the 70-200 f2.8 L IS. I put a candle on the table and it never locked up on me once. I tested in P, AV and TV modes.
This is an awesome lens but it would sound like you have one that needs some attention.
As was somewhat concluded in the other thread I would suggest you call Canon and get it in for a checkup.
JX
Joined Aug 2004
Oct 22, 2004 09:37 |  #8
Thank You SSIM
That what I need to know. Let me ask one question about your test. Did you allow the picture to be under exposed while in TV mode.
Jim
JX
JX
Joined Aug 2004
Oct 22, 2004 09:49 |  #9
Focus lock
Some one asked me a question yesterday that started me thinking. They asked if I had a focus lock. If you don't have a focus lock, I assume the Mark II will still take the picture. But now I am wondering if this is when the problem occurs. Focusing is more difficulty in low light. I never consider focus lock. I am going to experiment again, and see if the green light is blinking when this problem happens.
This problem only seems to happen when IS is on.
At this point I just want to understand the problem, so I can give a clear concise explanation to Canon's repair service.
JX
KennyG
Joined Aug 2003
Oct 22, 2004 10:47 |  #10
F2.8, ISO200 and speeds up to 1/1000 taking lots of black frames and no problems. It isn't something that one would do anyway and I wouldn't even attempt to take a shot that wasn't possible.
As I have said before, I do not think this is a generic problem and some people are trying to claim it is. Take the thread on RG, even though it looks full of complaints, by the time you count the actual number of people with a problem it is a very few. DPR, the home of the whingers, has only had a couple of short threads on the issue and only about two or three people saying they have the problem. I'm not being defensive or claiming there isn't a problem, but please get it into perspective. There are times like this when the internet is more of a hinderance than a help.
However, I have done what you requested and my negative results are probably no help at all. Another question for you - do you have any other IS lenses that you can do the same test with? You should be trying to eliminate the camera from the equation. Do you know anyone with a MK-II or 20D that could carry out the test with your lens? It could save you a lot of to and fro to Canon and give them some facts to work with.
Ken
Professional Motorsport Photographer
2 x 1D MK-II, 7D, 17-40L, 24-70L, 70-200 2.8L IS, 100-400L,
300 2.8L IS, 500 4.0L IS, 85 1.8, 50 1.4, 1.4 & 2.0 MK-II TC.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Oct 22, 2004 11:04 |  #11
FYI,
I have spent the last two days working with the 70-200mm IS on mostly the MkII but also on the 20D.
I am currently in production of Festival Ballet's "Witches Broom" world premeir (opens tonight)
The 4 gigs or so of photos were all taken during VERY dark rehearsals.
IS on, all at f/2.8, ISO 800/1600 or even 3200, (mostly 1600 though) ...with shutter speeds ranging from 1/2 second to 1/300th ... mostly hovering around 1/40th to 1/125th or so. (dark)
I have not had a lock up.
The one Lock up I have had with the MkII and 70-200 is documented in the RG thread so I won't repeat it here. But it was NOT so dark then, and I was shooting at f/3.5
CDS' HOT LINKS
JX
Joined Aug 2004
Oct 23, 2004 22:01 |  #12
The problem is definitely with Image Stabilization. I did some expensive testing. The problem only happens when “IS†is on. Monday I guess I will call Canon.
JX
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Oct 24, 2004 00:25 |  #13
On the first page of that RG forum thread.. it is one of our Canon Digital Top contributors.. Roger Cavanaugh.. who first mentions having Canon replace the IS assembly to fix this issue....
He seems satisfied, and that was many months ago.
Good luck JX,.. hope it all gets fixed.. the first time!
CDS' HOT LINKS
samdring
Joined Aug 2003
Oct 24, 2004 05:38 |  #14
Did you try removing the candle ?!
Have a Care
Sam
f8
Joined Apr 2004
Oct 26, 2004 11:11 |  #15
hi all
shooting a rugby match with the 100-400L had the same happen, err 01, never happened before but this is the first time shooting jpg rather than raw, ok so i know unlikely but thats the only change in 6 moths of shooting with lens/body combo
2,959 views & 0 likes for this thread, 10 members have posted to it.
1696 guests, 103 members online
