Thread started 22 Oct 2004 (Friday) 20:06
10D and Canon EF 28mm f/2.8 Lens...
chops
Joined Oct 2004
Oct 22, 2004 20:06 |  #1
Just for the heck of it, I barrowed the Canon EF 28mm f/2.8 lens from work tonight for a local classic car club get-together. Anyway, I had both my batteries fully, freshly charged when I got to the show. After only about 15 minutes or about 30 shots, the display on my 10D was showing the battery as being almost dead! I switched it out and put in the other fresh battery. The same thing happened again!
Now keep in mind, I only used the pop-up flash for maybe 3 or 4 images. Other than that, I was just using available light.
When I got home, I charged one of the batteries. This gets weird here too. The battery only took about 15 minutes to fully recharge! After that, I put it back in the camera, and within a few shots, it was showing dead again. So I put the other battery back in the camera without recharging it, but now with the 50mm f/1.8 lens mounted. The battery was reading a full charge again, and lasted for well over the 200+ shots I took around the house, all with the flash on at all times! It's still going strong as is the other battery.
Obviously, there must be some kind of issue with that 28mm lens and the 10D body. Has anyone else had this problem? Or does anyone know what the problem might be? I'm just curious about it.
Canon 10D w/ BG-ED3 Grip
Canon EF 50mm F1.8 Mk II
Canon EF 28-105 F3.5-4.5 Mk II
SanDisk 2GB Ultra II & Extreme III
http://charlest.zenfol​io.com/ (external link)
robertwgross
Joined Nov 2002
Oct 22, 2004 20:31 |  #2
Based on the symptoms, it certainly sounds like there is something funny in that one lens.
Further, that is the sort of lens problem that is easily overlooked when anybody does a very quick test on it. Something like a power fault inside the lens would only be detected over minutes or hours, and quick tests are generally done in ten seconds or less.
Maybe a trip to Canon is called for.
---Bob Gross---
chops
Joined Oct 2004
Oct 22, 2004 20:49 |  #3
Yeah, since it is store stock, we can get it replaced in a matter of days for free. It's just strange that it did that with my camera. It's a decent little lens, but still not as nice as my 50mm f/1.8. 8)
One other thing.... the focusing is rather loud on that 28mm lens too! I wonder if that has anything to do with it as well?!
1,196 views & 0 likes for this thread, 2 members have posted to it.
1787 guests, 130 members online
