Thread started 29 Feb 2008 (Friday) 17:04
40D Control Dial Issue
Mr ­ B ­ Pix
Feb 29, 2008 17:04 |  #1
My 40D came today. The control dial on the back was working as I went through the settings. I took a few test pictures, and now the dial won't work at all. Tried both the "On" and "Angle" positions, changing the battery, etc. Still no luck. Any suggestions? This really stinks, I guess I'll have to continue using my XTi until I get this resolved. I've got alot of pictures to take this weekend!
P.S. Bought it from Amazon. How is their return policy?
rdricks
Gallery: 13 photos
Feb 29, 2008 17:17 |  #2
It's probably fine. Check the on/off switch. There are two on positions. The one with the --- (all the way on) enables the quick control dial. If you only turn it on one notch the dial is locked to keep you from inadvertently making changes.
If there really is a problem, Amazon is pretty good for exchanges (although it would stink to have to wait to play with the new toy!)
-Ryan
My Photo Adventure (external link)
apersson850
Gallery: 35 photos
Feb 29, 2008 17:18 as a reply to  @ rdricks's post |  #3
For what purpose does it not work?
Anders
Mr ­ B ­ Pix
Feb 29, 2008 17:22 |  #4
apersson850 wrote in post #5022643 (external link)
It doesn't work for anything. This is true for both the ON setting and the Angled Line past On setting.
DSMITH131
Joined Jan 2005
Feb 29, 2008 17:38 |  #5
Call Amazon you can go to their website it has their Returns Policy You shouldn't have a problem returning it
Daniel W. Smith Photography (external link)
Mayhem (external link)
Gear
PBeeee
Feb 29, 2008 17:40 |  #6
And you're not on any of the Auto settings? Its only a control in a manual setting.
AdamLewis
Feb 29, 2008 17:41 |  #7
PBeeee wrote in post #5022744 (external link)
Or P/Av/Tv modes. If youre in the green box mode or any of the scene modes, it wont do anything.
apersson850
Gallery: 35 photos
Feb 29, 2008 17:53 as a reply to  @ AdamLewis's post |  #8
If you press the playback button (lower left), can't you scroll through the images you've taken either? That should work in any mode, and also irrespective of the power switch setting.
Anders
Mr ­ B ­ Pix
Feb 29, 2008 18:07 as a reply to  @ apersson850's post |  #9
The dial will not work in ANY mode ~ Green Idiot Box/P/Tv/Av/M
It will not scroll through the Menus.
It will not change White Balance / Drive Mode / FC
It will not scroll through the pictures one at a time when viewing them.
The Dial seems pretty much dead. The SET button works. Go figure.
I have tried with different lenses on and off. I have removed both batteries. I used the multi-point controller to reset all the camera settings - didn't help.
I am really disappointed. I have a basketball game on Saturday and a soccer tournament on Sunday to shoot. At least I still have my XTi.
Let me know if there are any other suggestions. FYI...I am not a newbie and I do know my way around a camera pretty well. And yes, I have read the manual a few times through (even before I ordered the camera). I am just frustrated at this point.
handyhaver
Feb 29, 2008 18:12 as a reply to  @ Mr B Pix's post |  #10
Sounds like it's time to send it back.............shoul​d have no problem returning it.
You can check out any time you like....,but you can never leave. 40D, 24-105 f4LIS, 70-200 f4LIS[COLOR=black],100 f2.8LIS macro, Sig 50mm f1.4 , Sig 10-20 , 580EXll ,430EX, ST-E2, S2IS
http://handyhaver.zenf​olio.com/ (external link)
PBeeee
Feb 29, 2008 18:16 |  #11
Sounds like it needs to go back. I hate to see someone lose a new toy on a Friday......
MNMOXIE
Feb 29, 2008 20:44 as a reply to  @ PBeeee's post |  #12
Have you tried reverting all settings back to default settings? Maybe the dial got remapped to do another function.
40D, rebel xt, 18-55mm kit, 75-300mm kit, 100-400mm IS L, 28-135mm IS, Tameron 1.4 TC, Lowepro Vertex 200 AW, Bogen TP/Manfrotto head (pistol grip), Various Filters, Epson R2880 Printer
statsman
Feb 29, 2008 21:35 |  #13
Does the Quick Control Dial work with no lens attached and the CF card removed?
DSMITH131
Joined Jan 2005
Feb 29, 2008 22:41 |  #14
statsman wrote in post #5024041 (external link)
Yes sir
Gear
Calicajun
Gallery: 11 photos
Mar 01, 2008 00:00 as a reply to  @ DSMITH131's post |  #15
A suggestion I picked up from a thread on this board and it worked for me, that was to take battery out of the camera then turn the camera switch to on. Turn the camera back off and wait about ten minutes before putting the battery back into the camera. Sounds silly (which is what the OP said too) but it worked for me, haven't had a problem since.
Remember, Stressed spelled backward is Desserts.:)
Suggestions welcome.
Sony A7rIV, Sigma 24-70 f2.8, Sigma, 14-24 f2.8, Sony 100-400G, Godox V860II
2,645 views & 0 likes for this thread, 11 members have posted to it.
559 guests, 121 members online
