I have a question to ask you all - one that has been puzzling me for a while.
I have a 10D, a 420EX, an older Cobra flash with the Canon mount, a hammer head flash and a couple of studio lights. Sometimes when shooting indoors I do not want to use the studio lights and prefer to use some of the battery operated flashes mentioned above. As a general rule I will connect the hammer head to the 10D with a sync cable and then slave the Cobra.
The problem I get is that all is fine for the first shot, but on subsequent shots the slave unit will not fire the Cobra (even the test fire button will not work?). I have swapped the slave unit onto the 420 and the same problem persists. I have tried a number of slave units (from different manufacturers) and the problem is still there. If you disconnect the slave unit from the flash and reconnect it will work once and then lock again. The only thing I can think of is that there is either something odd with the Canon mount (although I find this hard to believe) or there is a polarity issue, I cannot see any other commonality that could cause the problem.
Any ideas would be greatly appreciated as I do not want to have to use cables between all the flashes.
PS - I bought a second hand 70-200L F2.8 lens yesterday and cannot wait to try it out (really crap weather here in England at the moment). Only problem is that it is a tight fit in my gadget bag - but this is a good problem
Cheers,
Mark.
