Thread started 01 Mar 2008 (Saturday) 04:03
Another hairlight idea for Speedlites
Lotto
Mar 01, 2008 04:03 |  #1
I want to use this Alien Bees 7" reflector with the grids as hairlight for Speedlites. The simple mod starts with 2 piece L brackets, joint together with a bolt, the idea was to separate them for easy storage. Since the reflector and grid together weight only couple ounces, I use 3M double side tape to stick the L bracket to the reflector. The back shielding disk is made out of cardboard.
IMAGE: http://farm4.static.flickr.com/3072/2301916654_bd20688875_o.jpg
Use the small ball head to hang the hair light on a boom arm, it could be pointed to any direction.
IMAGE: http://farm3.static.flickr.com/2357/2301124109_766330f208_o.jpg
Test pics with the prototype. The AB grid does great job for flare control.
IMAGE: http://farm3.static.flickr.com/2175/2301123983_3cc8b7c6fa_o.jpg
What you think?
5D, 24-105L, 70-200L IS, 85mm Art, Godox
Curtis ­ N
Master Flasher
Mar 01, 2008 09:25 |  #2
Lotto, your inventions always look professional and work well. I just don't know if it's really better than a simple snoot or strobist-type drinking straw grid attachment in practical usage?
Lotto
Mar 01, 2008 11:17 |  #3
Curtis, I could've gone Strobist route if I don't already own the set of AB grids and gels, and since I use softboxes for my Bees, those reflectors are sitting on the shell most of the time.
I think this setup is more efficient to tramsmit/reflect the light forward than the staws, plus a bit softer light.
IMAGE: http://farm3.static.flickr.com/2059/2302620624_b815eee4de_o.jpg
Stefano7
Mar 01, 2008 13:58 |  #4
Lotto - very creative and a fine looking hairlight mod. Plus, as you point out, probably delivers good directional, soft light. I find really interesting the DIY adaptations that closely approximate expensive accessories - also some good ones on FM occasionally.
Thanks for the post!
Stefano7
Mar 01, 2008 15:20 |  #5
Here's a post on FM for a DIY snoot using drinking straws much like Curtis mentioned:
http://www.fredmiranda​.com/forum/topic/62096​7 (external link)
1,700 views & 0 likes for this thread, 3 members have posted to it.
1589 guests, 137 members online
