Thread started 01 Mar 2008 (Saturday) 19:18
recommend ballhead for 70-200 2.8L on XTi/400D
sneakerpimp
Mar 01, 2008 19:18 |  #1
i'm thinking about this
rated for 5.5 lbs. i don't know anything about ballheads, please help me out. it will be mounted onto an Induro monopod. i wasn't sure if i needed a larger mount area or whatnot. not interested in quick release. trying to stay under $50 and want something very light (under 9 oz). thanks.
Canon EOS M | G7 X | S90
patrick835
Mar 01, 2008 20:15 |  #2
my opinion is, when you already invested you money in suck a lens like that, you shouldn't put it on risk. :D
you need something that can hold up to at least 11 pounds, not 5.5. :p and don't buy anything under 100 'cause you're gonna throw it away to get a better one soon.
1D mk II + sigma 10-22 + 100f/2.8 + 70-200/f4L + f/2.8L IS II+ tamron AF 2x + 430EX II
[COLOR=darkgreen] 2x Canon 30D + 2x BG-E2N + 18-55 kit + 50mm f/1.8 II + 85 f/1.8 + 100mm Macro + 70-200f/4L + 17-40f/4L + 430EX + 580 EX II + RRS L plate + Markin Q3 + Gitzo G2220
completely broke :lol:
lanz4
Mar 01, 2008 22:11 |  #3
I have this lens and a 30D. I just bought the Giottos MH1302 w/the MH655 QR plate which supports 18 lbs. Your camera and lens weight about 5.3 lbs. This is a light ballhead that will do the trick and bear the valuable load. This combo is $120 from B&H. Here's the link:
http://www.bhphotovide​o.com …H_1302_Pro_Seri​es_II.html (external link)
SkipD
Joined Dec 2002
Mar 02, 2008 02:02 |  #4
The Manfrotto 488RC2 will also do quite well at about $100. It is a little heavier, but works quite well with the heavier lenses.
To get lightweight equipment that performs like a heavyweight, expect at least the pricing to be heavyweight. You cannot get something for nothing.
Skip Douglas
kchau
Mar 02, 2008 03:17 |  #5
SkipD wrote in post #5031200 (external link)
i second that motion, i have a 488rc2, and the thing is a tank. the midi (panning?) base makes it great for panoramas as well.
Fujifilm
agedbriar
Mar 02, 2008 09:41 |  #6
I opted for the Manfrotto 488RC2 as well.
I was first thinking about the 486RC2 (RC2 stands for the rapid connect system) as being sturdy enough, but then I felt that having one single lock for both the ball and the panorama movement would not be very practical. Setting the drag with the main lock on the 488 is fast and confortable.
Ballheads with a separate thumbwheel for the drag setting are generally more expensive and I suppose you have to reset the drag when you change lenses anyway.
The rapid connect system is a fine thing to have.
Eagle ­ Eye
Joined Jan 2005
Mar 02, 2008 09:52 as a reply to  @ agedbriar's post |  #7
I agree, 488RC2 all the way. Skip doesn't know it but I also bought mine from reading the posts he has recommended it on. I figured by this one now and then when the bigger lenses are bought I still have a ballhead I can use on monopod as well as tripod with just changing the head since I already would have the quick release. Just my 2 cents.
Simple Canon G9.
sneakerpimp
Mar 02, 2008 12:45 as a reply to  @ Eagle Eye's post |  #8
i forgot to mention i'm new at using a monopod, so i don't know if i'll even need a ballhead and after looking up several sports shooter setups i decided to try going without. thanks for all the replies.
tgara
Mar 02, 2008 19:34 |  #9
sneakerpimp wrote in post #5033352 (external link)
I was going to ask that. Why do you want a ball head on a monopod? I have a Gitzo monopod with a Manfrotto 3232 tilt head, and its great. A ball head is too much for a monopod, in my opinion.
EOS 5D Mark III
EOS Rebel SL1
Full Gear List
argyle
Mar 02, 2008 19:41 |  #10
tgara wrote in post #5035852 (external link)
Yep...I'm using the 3232 also, with a RRS lever clamp attached. Didn't see the need for a ballhead...
Scott-LYP
Mar 02, 2008 19:44 as a reply to  @ argyle's post |  #11
Agreed. The ballhead on a monopod is overkill...
Leap Year Photography - Fort Myers Photographer http://leapyearphoto.c​om (external link)
2x Canon 7D | Canon 70-200 f/2.8 L IS | | Canon 16-35mm f/2.8 L II | Canon 50mm f/1.2 L |Canon 24-70 f/2.84 L | 580EX II + 580EX
Ultimate ­ CC
Mar 02, 2008 19:45 |  #12
arca swiss z1
My Gear And For Sale Items
www.danhonovich.com (external link)
www.danhonovich.blogsp​ot.com (external link)
Familiaphoto
Mar 02, 2008 19:48 |  #13
Some like to use ballheads on monopods as they might put the monopod horizontal and the ballhead would allow them to keep the camera oriented as they like. All depends on your needs.
Paul
Blog (external link) | Gear (external link) | Gallery (external link)
Bag Reviews: Domke F-3x | More to come...
Eagle ­ Eye
Joined Jan 2005
Mar 02, 2008 20:24 as a reply to  @ Familiaphoto's post |  #14
Plus when things are tight you can get by with one (488RC2) and then use it on Mono or Tri as needed. Works for me.
Simple Canon G9.
GaterMan
Joined Nov 2005
Mar 04, 2008 14:18 as a reply to  @ Eagle Eye's post |  #15
is the 3232 on a monopod strong enough for the 70-200 2.8L ?
art has no rules :)
2,985 views & 0 likes for this thread, 16 members have posted to it.
1366 guests, 170 members online
