Thread started 03 Mar 2008 (Monday) 18:12
Slik 813 vs Manfrotto 055 MF3
Leigh
Joined Apr 2003
Mar 03, 2008 18:12 |  #1
Hi,
My Feisol pod broke, and I'm looking for a sturdy, better constructed, 3 leg replacement.
Heaviest gear would be 40D with 100-400L (3 lb), and a Manfrotto 3421 Gimbal head (3.1 lbs); which brings the weight up to about 8 lbs.
I have no doubt that the Manfrotto MagFiber, with it's 15.4 lb rating would be up to the task; but the lighter weight, & taller closed height of the Slik 813 is appealing.
I just wonder if the Slik, with it's 12 lb rating would be sturdy enough; as some pod manufacturer's weight limitation ratings are a bit ambitious.
Anyone with experience with either, or both???
Regards,
Leigh
jdkeck
Mar 03, 2008 21:46 |  #2
I have the 055MF tripod and am very happy with it. I have a Manfrotto 50mm leveling ball center column and RRS panoramic head, and use a 5D with up to a 200mm 2L lens. The light weight of the tripod is a disadvantage with that much weight, but I either hang my pack which is 15-20 pounds or a 10 pound weight to stabilize the tripod. I personally can recommend the 055MF.
No experience with the Slik.
Jeff
Life is not measured by the number breaths we take but by the moments that take our breath away.
hjohnson
Mar 03, 2008 22:00 |  #3
I just picked up the 055MF3 + 388RC2 ballhead, and it's a pretty good combination. The whole thing is rock solid with my 40D+Grip+300mm F/4+1.4x TC.
My only 'complaint' with the tripod is that the legs are so light that they don't drop under their own weight when I release the levers. :D (and if that's all you have to complain about, that's pretty damned good. :D)
ELAN 7E, 350D + Grip, 40D + Grip, EF-S 17-55 f/2.8 IS, EF 28-105 f/3-4.5 USM II, EF 70-200 f/4L IS, EF 28 f/1.8 USM, EF 100 f/2.8 USM Macro, EF 300 f/4L IS, EF Extender 1.4x II
Tsmith
Formerly known as Bluedog_XT
Mar 03, 2008 22:26 |  #4
Um _ how'd it break? I always thought the Feisol brand where rated fairly good.
illusionest
5D MkII? CHECK!
Mar 03, 2008 22:28 |  #5
i have the EXACT same setup, 055MF3 with 3421 head, on 40D with grip, 100-400, and it is perfectly fine. No problems what-so-ever.
picture of my setup (tripod not shown, but it is the 055MF3):
http://img527.imagesha​ck.us …/8058/birdsetup​newio9.jpg (external link)
^ 580EX II and better beamer in there too.
Matthew Law
Gallery (external link) | My Gear | IG: @matthew.law (external link)
3,943 views & 0 likes for this thread, 5 members have posted to it.
1457 guests, 129 members online
