Thread started 04 Mar 2008 (Tuesday) 18:56
Input: Anyone use the HOYA "purple" line UV and CP filter?
_Dc
Mar 04, 2008 18:56 |  #1
Hey,
A local is selling this Hoya purple line filter kit for $60.
Wondering if anyone has had any positive or negative experiences with these filters?
Does it matter how many layers are on the filter?
Here's a link for reference
http://cgi.ebay.com ….m118.l1247QQcm​dZViewItem (external link)
thanks
Jon
Joined Jun 2004
Mar 05, 2008 08:53 |  #2
Don't waste your money; they're uncoated (polarizer) and minimally coated (UV). Multi-coating cuts down both light loss and flare-inducing reflections; for Hoya filters, S-HMC is the minimum level you should consider. The B+W equivalent level is MRC; with Heliopan it's SH-PMC. Other filter brands aren't really worth considering as a rule.
Jon
Cocker Spaniels
_Dc
Mar 05, 2008 12:36 |  #3
Thanks Jon. Now if I get the Heliopan CP without the multi-coat, would that help with flare reductions? I know you stated above that the multi coat helps with the flare reduction but what does a CP filter do without the coating? I'd like to have the SH-PMC but that is a little bit more.
Jon
Joined Jun 2004
Mar 05, 2008 13:09 |  #4
Multicoating is the only thing that'll help reduce lens flare if the light can reach the lens; a polarizer is no less susceptible to flare from light striking it than a UV filter. It'll still handle the normal duties of a polarizer, but you'll need to be extra careful to keep light sources out of the lens' field of view.
Jon
Cocker Spaniels
1,880 views & 0 likes for this thread, 2 members have posted to it.
1102 guests, 117 members online
