Could I duplicate polarizing filter effects using pp software eg: DPP or CS3? I 'm guessing it's better to have the polarizing filter on the camera rather to do pp after, if latter is possible. Can any of you share your experiences?
Ta.
sandpiper Cream of the Crop More info | Mar 05, 2008 15:26 | #2 You can replicate the effects of a deeper blue sky and nice clouds in software, but the way a polariser reduces / kills reflections can't be done with any reasonably simple method. It may be possible to go over the entire picture, a bit at a time, with cloning and healing tools to smooth and remove reflections in some cases, but only if you are a highly skilled retoucher and prepared to spend hours on each image.
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Mar 05, 2008 15:42 | #3 Just the sky color changing properties, but not the alterations they have on reflections. [Gear List | Flickr
ypx3 Senior Member 388 posts Joined May 2007 Location: Kalamazoo, MI More info | Mar 05, 2008 15:44 | #4 sandpiper wrote in post #5054946 You can replicate the effects of a deeper blue sky and nice clouds in software, but the way a polariser reduces / kills reflections can't be done with any reasonably simple method. It may be possible to go over the entire picture, a bit at a time, with cloning and healing tools to smooth and remove reflections in some cases, but only if you are a highly skilled retoucher and prepared to spend hours on each image. So, no, there isn't a way of realistically reproducing the effects in software. What is the best technique to make a deeper blue sky in PS. Always wanting to learn
argyle Cream of the Crop 8,187 posts Likes: 24 Joined Apr 2007 Location: DFW, Texas More info | Mar 05, 2008 16:07 | #5 ypx3 wrote in post #5055052 What is the best technique to make a deeper blue sky in PS. You can set your foreground color to 'black' and apply a gradient layer. If done right, it looks pretty good, but not as good as when using a polarizer. Here's a before and after shot. This was shot with a 5D and the Canon 15mm fisheye, so use of a threaded filter was out. The first is the 'normal' shot, the second has a gradient layer applied in Photoshop. Gradient Layer: I should add that I played with the contrast a little in the gradient image...the gradient was only applied from the curvature of the upper rim to the top. Below the rim was not affected by the gradient layer. "Fat, drunk and stupid is no way to go through life, son". - Dean Wormer
sandpiper Cream of the Crop More info | Mar 05, 2008 16:08 | #6 ypx3 wrote in post #5055052 What is the best technique to make a deeper blue sky in PS. I would actually use lightroom for that as you can select the blue colour channel and alter the hue and saturation just for the blues. The channel mixer in lightroom is fantastic for altering specific tones.
argyle Cream of the Crop 8,187 posts Likes: 24 Joined Apr 2007 Location: DFW, Texas More info | You can also do a 'selective color' adjust. Simply choose the 'cyan' color from the dropdown and adjust its black channel to 20 or 30. Then, select the 'white' color from the dropdown and adjust its black channel as well, again to 20 or 30. These numbers are guides...you can adjust to whatever your preference. Again, as in my example above, its just doesn't give the same results as using a CPL. "Fat, drunk and stupid is no way to go through life, son". - Dean Wormer
ypx3 Senior Member 388 posts Joined May 2007 Location: Kalamazoo, MI More info | Mar 05, 2008 17:37 | #8 Thanks for all the help, I don't have a CPL and when I did I never found myself using it, I will consider purchasing one but the problem is I have three lenses with three filter sizes. Always wanting to learn
sandpiper Cream of the Crop More info | Mar 05, 2008 18:43 | #9 ypx3 wrote in post #5055696 Thanks for all the help, I don't have a CPL and when I did I never found myself using it, I will consider purchasing one but the problem is I have three lenses with three filter sizes. Me too. I also have 3 CPLs
Jbs Senior Member 762 posts Likes: 2 Joined Jan 2008 Location: Los Angeles More info | Mar 05, 2008 19:04 | #10 You can use the burn tool a big radius set to around 7%. Website - johnbattephotography.com
ypx3 Senior Member 388 posts Joined May 2007 Location: Kalamazoo, MI More info | Mar 05, 2008 19:07 | #11 argyle wrote in post #5055202 You can set your foreground color to 'black' and apply a gradient layer. If done right, it looks pretty good, but not as good as when using a polarizer. Here's a before and after shot. This was shot with a 5D and the Canon 15mm fisheye, so use of a threaded filter was out. The first is the 'normal' shot, the second has a gradient layer applied in Photoshop. I should add that I played with the contrast a little in the gradient image...the gradient was only applied from the curvature of the upper rim to the top. Below the rim was not affected by the gradient layer. sandpiper wrote in post #5055212 I would actually use lightroom for that as you can select the blue colour channel and alter the hue and saturation just for the blues. The channel mixer in lightroom is fantastic for altering specific tones. In PS you could select the sky area and play with the saturation on that, or simply use the burn & sponge tools to darken and saturate the sky. I have seen a tutorial on exactly reproducing the tonal affect of a polariser on the sky, and it was a little more complicated than that, but that will make a start. Personally, I just stick a CPL on the camera and don't have to worry about fixing it later .argyle wrote in post #5055267 You can also do a 'selective color' adjust. Simply choose the 'cyan' color from the dropdown and adjust its black channel to 20 or 30. Then, select the 'white' color from the dropdown and adjust its black channel as well, again to 20 or 30. These numbers are guides...you can adjust to whatever your preference. Again, as in my example above, its just doesn't give the same results as using a CPL. All great advice, all far above my PS skill unfortunately but I will practice and see if I can't make it better. Always wanting to learn
DDCSD GIVIN' GOOD KARMA 13,313 posts Likes: 3 Joined Jun 2007 Location: South Dakota More info | Mar 05, 2008 19:24 | #12 ypx3 wrote in post #5055696 Thanks for all the help, I don't have a CPL and when I did I never found myself using it, I will consider purchasing one but the problem is I have three lenses with three filter sizes. You could always get one for the biggest thread size and get some step-up rings for the other lenses. Derek
| Latest registered member is Mihai Bucur 950 guests, 139 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
