I have been on the fence for a while regarding purchasing one to use with my two 550EXs.
The Radio Poppers have added to my interest in the ST-2.
I figure if the range of the ST-2 doesen't cut it, I could get Radio Poppers.
Mar 05, 2008 23:18 | #1 I have been on the fence for a while regarding purchasing one to use with my two 550EXs. Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
sml Senior Member 511 posts Likes: 1 Joined Feb 2008 More info | Mar 06, 2008 10:17 | #2 I just got the ST-E2 last week. I've been playing around with it....literally. I did shoot one photo to send out via e-mail and the response was that the photo looked like a studio shot! One off camera 550EX and the ST-E2 on the camera. I intend to build from there---additional flashes, diffusion box, umbrella, etc. Steve L
cosworth I'm comfortable with my masculinity 10,939 posts Likes: 21 Joined Jul 2005 Location: Duncan, BC, Canada More info | Mar 06, 2008 10:22 | #3 I love firing optical slaves with mine. people will always try to stop you doing the right thing if it is unconventional
digitaljoe Senior Member 345 posts Joined Mar 2006 Location: Cape Town South Africa More info | Yes. Excellent indoors - the range will surprise you. I don't use mine outside in sunlight. Its fine in the shade though.
dou_b_14 Senior Member 955 posts Likes: 1 Joined May 2006 Location: RGV Texas More info | Mar 06, 2008 12:16 | #5 Had it for over a year and loved it until it started letting me down on PAID shoots. I would have the problem of it only firing 1 580 and not the other. So i just threw it aside and bought PW's. I shoot in full manual either way so i dont really miss the ettl. It was embarrasing to not have my equipment working in front of my clients. Canon 5d w/grip / canon 7d/ canon G1X/ 24-70mm 2.8 L/ 17-40mm L/ 50mm 1.4/(2)580ex/ pw's (3) /st-e2/ (2)cp-e3 battery pack/ abr800/ vagabond 2/ calumet genesis 200w(2)/
sleibrand Senior Member 635 posts Joined Jun 2007 Location: Ohio More info | Mar 07, 2008 01:16 | #6 I've not used mine extensively but I've not seen any issues with it. I use it indoors with ettl and 2x 420EX's. It does what I'd expect it to do. Being able to set ratios between the 2 strobes is a nice feature. Canon Gear: 5D3, 6D, 7D, 20D, 16-35 II, 24-105, 70-200 f2.8 IS II, 35L, 50 f1.4, 50 f1.8, 50 f2.5, 85 f1.8, 400 f5.6, 1.4x, 600EX (x2), ST-E3
inward/outward Member 244 posts Joined Oct 2007 More info | Mar 07, 2008 14:40 | #7 Permanent banFrankly, after getting used to manual flash and using master/slave setups with the Canon system and PWs, I simply sold my ST-E2 which I never even used. The range on the PWs is much better and dependable and all you need is two to fire the master flash and the slaves are taken care of from there with the master flash. Whole bunch of gear (wouldn't want to bore you).
TexKen Senior Member 519 posts Joined Jan 2005 Location: Fort Worth, Texas More info | Mar 07, 2008 19:12 | #8 inward/outward wrote in post #5068104 The range on the PWs is much better and dependable and all you need is two to fire the master flash and the slaves are taken care of from there with the master flash. I'm confused... You use the PW to trigger an off camera master and then you just use the optical capabilities of the master to fire the slaves? Doesn't that defeat the purpose of the PW? I guess that's fine inside, but my understanding is that the optical triggering doesn't work all that well outside.
DavidPhoto Senior Member 777 posts Likes: 1 Joined Mar 2007 Location: MA, USA More info | Mar 07, 2008 20:20 | #9 it has its place. I wouldn't try to use it for everything but it does work well for some things namely off-camera flash with eTTL. It is good for small indoor events and certain types of on-location indoor shoots. Might be useful for wedding shots if you wanted to get the flash(es) off camera.
PTM Member 88 posts Joined Oct 2007 More info | Mar 18, 2008 19:13 | #10 I didnt want to start another thread as this question may have been answered already. Canon 5D, 40D, 60D, 10-22mm, 16-35mm mkii, 70-200mm 2.8, 100-400mm, 100mm Macro, 2x 580ex ii, ST-E2, Sigma 8mm Fisheye for 360 panoramas.
soilsample Member 33 posts Joined Mar 2006 More info | Mar 18, 2008 19:37 | #11 yes it will work with multiple 580exII and most other combinations of canon ettl flashes.
L.Morey Goldmember 1,571 posts Joined Oct 2005 Location: Modesto Ca More info | Mar 18, 2008 20:41 | #12 Does it work at all at night say for 5-10 feet?? Outside 7d gripped,40d gripped,G9,17-40f4L, 24-70f2.8 L, 70-200f2.8 mkll L, 100-400 f4.5-5.6 L, 50f1.4 , 85f1.8 , Sigma 24-70f2.8
Andrushka "all warm and fuzzy" 3,735 posts Likes: 12 Joined Oct 2007 Location: OC, CA More info | Mar 18, 2008 21:33 | #13 Permanentlyi love mine... works great and is so easy to set up http://www.paradigmphotographyoc.com
flying... Member 115 posts Joined Jun 2006 More info | Mar 18, 2008 21:50 | #14 L.Morey wrote in post #5144207 Does it work at all at night say for 5-10 feet?? Outside somebody please answer this. Leave some comments on my flickr, PLEASE. Thanks
BlueS2 Goldmember 1,352 posts Likes: 1 Joined Aug 2004 Location: US More info | Mar 18, 2008 21:53 | #15 Of course it will. It's infrared. Time of day has nothing to do with it. Canon 5DmkII / Canon 5D / LifePixel IR 350D / L-glass
| Latest registered member is semonsters 1444 guests, 139 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
