Thread started 06 Mar 2008 (Thursday) 17:19
Problem with Tiff
matthew ­ blake
Mar 06, 2008 17:19 |  #1
I made a panorama with autopano pro (quite big) and the jpg wouldn't open in photoshop because there were too many pixels horizontally so i converted it to tiff using acdsee and opened it in photoshop, did some work to it but now it won't let me save it as a photoshop document, jpeg or anything other than tiff, dicom, photoshop raw, or large document format. the file is 8 bits.. i converted it to 16 bits but still won't let me save in any other format. i need to be able to save this as a compressed jpg or i wont be able to send it to anyone.. thanks!
ssim
Joined Apr 2003
Mar 06, 2008 17:29 |  #2
I've never used ACD so I can't comment on whether that does something to the file but I would highly doubt this.
Have you check your color mode to ensure that it didn't accidentally get set to LAB or something else that will affect your save options. I can't think of anything else right now.
eddarr
There's Moderators under there....
Mar 06, 2008 18:05 |  #3
Do you have layers in the image. If so you will have to flatten before you can save as a jpeg.
Eric
D_A
Mar 06, 2008 18:14 |  #4
Try changing from 16bit to 8bit. Image > mode> 8bit
matthew ­ blake
Mar 06, 2008 21:24 |  #5
it is in 8bit mode already and was originally, tif was made from converted jpg, color is rgb, and there are no layers, image has been flattened and resaved as a tif.
ssim
Joined Apr 2003
Mar 06, 2008 21:26 |  #6
eddarr wrote in post #5062728 (external link)
Saving a layer file as a jpeg will automatically flatten the image in the save process. There is no need to flatten yourself but there is no harm either.
NZDoug
"old fashion"
Location: French Bay, on the shores of the mighty Manukau Harbour, Aoteoroa
Mar 06, 2008 21:27 |  #7
If it has any layers, embeded selects or paths, you will have to discard them before it can convert.
HEY! HO!
LETS GO!
matthew ­ blake
Mar 06, 2008 21:34 |  #8
well there are no layers, it just says "background image', im not sure what embeded selects or paths are? how do i check?
Bodog
Joined Feb 2004
Mar 07, 2008 00:01 |  #9
Strange problem. Have you tried "save as"?
JimE
Color? It's all relative...
mr_e
Mar 07, 2008 00:30 |  #10
My guess is that same size limitation that wouldn't let you open it, will only let you save it in formats that support that many pixels
Ian Johnson, Small Business Web Solutions (external link)
matthew ­ blake
Mar 07, 2008 01:01 |  #11
mr_e wrote in post #5064791 (external link)
you are correct, i cropped it down to see and was able to save it. its 32,424 pixels wide so i guess i'll have to resize it to save it to jpg since theres nothing i can crop, thanks
1,047 views & 0 likes for this thread, 7 members have posted to it.
Problem with Tiff
1049 guests, 116 members online
