Thread started 27 Oct 2004 (Wednesday) 21:29
HELP!!!! 10D Burnt Pixel on CCD!!?!!!!
45R
Joined Jun 2004
Oct 27, 2004 21:29 |  #1
I really need some input guys. I took a few pictures of the eclipse tonight and I noticed a purple shot in the same spot in all my pictures. This spot is really notable when shooting on black but with other colors its not as bright. What is it!?!! I checked the CCD for spots. Its clean!
I really appreciate anything suggestions!
Canon 7D, Canon 30D, Canon 580EX,28-135mm IS USM
50mm F1.8,15mm F2.8,18-55mm Kit lens
17-40L,70-200LF2.8 IS, 2X TC
FlipsidE
Joined Oct 2004
Oct 27, 2004 21:38 |  #2
How long was the exposure? I'm just curious. On exposures longer than 1/10, these things start showing up. It's no big deal. These are what is referred to as "hot pixels." Even the 20D's have 'em on long exposures. Just clone it out if it gets in the way.
FlipsidE
FlipsidE
defordphoto
MKIII Aficionado
Joined Oct 2002
Oct 27, 2004 21:42 |  #3
Just a side-comment: The 10D does not have a CCD. CMOS it does have. Hotspots happen. Use the heal tool and all is well.
defordphoto | Celebrating the art of photography®
SD500, 10D, 20D, 30D, 5D, 1DMKII, 1DMKIII
www.ussbaracing.com (external link) | www.rfmsports.com (external link) | www.nwfjcc.com (external link)
An austere and pleasant poetry of the real. Ansel Adams
45R
Joined Jun 2004
Oct 27, 2004 21:48 |  #4
The pictures were over exposed at .6 seconds others that I noticed were exposed at 1/8 of a second.
FlipsidE
Joined Oct 2004
Oct 27, 2004 21:52 |  #5
- Sounds about right then. Nothing to worry about.
FlipsidE
FlipsidE
45R
Joined Jun 2004
Oct 27, 2004 21:55 |  #6
OKay so if this thing is a hot spot and I can use the heal tool, thats cool but will it show up at the same spot each time?
I am pretty new to this hot pixel thing.
dschwartz69
Joined Aug 2004
Oct 27, 2004 21:57 |  #7
It is common amongst almost all digital cameras - you will see it at the exact same spot when it (or they) appear.
I freaked out a couple months ago when I first noticed mine on my, then new, 10D.
No worries...
David Schwartz
7D, EF 70-200mm L f/2.8 IS II, EF-S 15-85mm f/3.5-5.6, 50mm 1.4, 580EX II
www.DesertCreekPhotogr​aphy.com (external link)
45R
Joined Jun 2004
Oct 27, 2004 21:59 |  #8
Thanks for the help guys. I was about to lose it :) Sending something for repair at Best Buy is a nightmare!
Persian-Rice
Joined Apr 2004
Oct 27, 2004 22:27 |  #9
Burnt photosites will appear black. Hotspot, which basically means the photosites amplification settings have gone out of wack and has created much too much heat will give purple, orange, yellow, red, green or blue tones.
Some will appear all the time, known as stuck photosites or just random ones which is normal, especially at higher ISO's as amplification is magnified even more.
As said, just create an action that will auto repair this. One of my 10D's does this at 400-800+ ISO in one of the corners, especially if there is something dark in that area which will make it more obvious. Anyway, it's really easy to fix.
Believe it or not, if you operate the camera under cooler conditions, hotspots will be far less noticeable.
Cheers.
Ed ­ Rotberg
Joined Nov 2003
Oct 27, 2004 23:22 |  #10
You can also send the camera into Canon to have the hot and dead pixels remapped. It probably doesn't cost a whole lot. If you ever have a time when you aren't going to be needing your camera for a week or so, you might think about this.
Just about every CMOS/CCD sensor has these - even right off the line. That's why mapping out bad pixels isn't a big deal. It's almost certain that your camera came from the factory with a number of thse already mapped out. The yield of 100% perfect sensors would make the cost of a digital SLR prohibitive. On the bright side, mapping out a handful of pixels out of 6+ million is pretty much not noticable.
= Ed =
Ed Rotberg
"A waist is a terrible thing to mind!"
My Gallery (external link)
Andy_T
Joined Jan 2003
Oct 28, 2004 03:47 |  #11
Ed,
that sure sounds interesting!
Do you have further information (e.g. sources or testimonials from users who had it done) on this how it is technically done and where at Canon I could send my camera?
Best regards,
Andy
some cameras, some lenses,
and still a lot of things to learn...
(so post processing examples on my images are welcome :D)
If you like the forum, vote for it where it really counts!
CLICK here for the EOS FAQ
CLICK here for the Post Processing FAQ
CLICK here to understand a bit more about BOKEH
Ed ­ Rotberg
Joined Nov 2003
Oct 28, 2004 09:26 |  #12
Andythaler wrote:
Ed,
Best regards,
Andy
Well,
I had it done to my 10D in June. With SLR camera I have purchased since about 1978 or so, just before the camera goes out of warranty I send it in for cleaning/adjustment, etc. Since th 10D was my first DSLR, I requested that the camera also be checked for dead/hot pixels and that they remapped them. IIRC, the service record came back indicating that the remapping had been done, and I know that I checked for the one bad pixel I had noticed and it appeared to be gone.
As for technically, I've read somewhere that the software in the camera keeps a table of known bad pixel locations. It then substitutes an average of the actual data from the surrounding pixels for those locations. I've been a professional graphics programmer for over 30 years, and this seems like the obvious approach, so when I read this, it made total sense. My guess is that they use a weighted average of the surrounding pixels, giving the more weight the the axially aligned adjacent pixels than the diagonally adjacent pixels, but that is pure specualtion. That's how I would do it though.
Just send the camera into any Canon Service Center (I sent mine into the Irvine, CA center) with a letter indicating the service you wish performed, and, if appropriate, the receipt indicating that the camera is still under warranty. You might as well ask them to do a general tune-up, sensor cleaning, etc. while it is there.
= Ed =
Ed Rotberg
Andy_T
Joined Jan 2003
Oct 28, 2004 10:26 |  #13
Ed,
that is very interesting and useful information, thank you 8)
I'll inquire whether Canon can also do that on my G2, which has several hot pixels by now. It might be slightly out of warranty, though :wink:
Best regards,
Andy
timmyquest
Joined Dec 2003
Oct 28, 2004 10:33 |  #14
Andythaler wrote:
Ed,
Best regards,
Andy
Indeed, i always thought of it as a hardware only problem. I never figured it could be managed through software
Capturing life a fraction of a second at a time
Persian-Rice
Joined Apr 2004
Oct 28, 2004 15:19 |  #15
timmyquest wrote:
Andythaler wrote:
Ed,
Best regards,
Andy
Amplification of the signal is all software controlled *eherm eherm* it's called ISO setting. Therefore the software can actually reduce amplification. I am assuming they are using some form of sensor system that records temperature readings and as Ed said, averages out using some mathematical formula.
Another reason that the "sensor tracking" system makes sense is. I really doubt Canon want to sit there and run hot or dead pixel tests and then start going through an image trying to segregate pixels and find the corresponding photosite on the sensor. I also think it would make sense to do that, since problematic pixels are not uncommon.
3,658 views & 0 likes for this thread, 9 members have posted to it.
2455 guests, 101 members online
