Thread started 08 Mar 2008 (Saturday) 21:17
Help on making pictures in the dark
sakurablossoms75
Mar 08, 2008 21:17 |  #1
I use the Canon G9 camera, but when taking pictures in the dark, the pictures are very blurry and grainy (I only take pictures in .CR2 btw, no JPGs).
Anyone can help me to optimize the settings to make clearer and better pictures in the dark?
Thanx in advance
Canon 5D2, Canon G9
EF 50mm f/1.2L USM, EF 24-105mm f/4L IS USM, 580 EX II
CJinAustin
Mar 09, 2008 00:37 |  #2
You need to learn how the camera works,, your ISO setting will need to be higher, your aperture bigger, and your shutter speed appropiate for the zoom. etc.
- GEAR -
Canon 1Ds Mark V | Canon 5D Mark IV | Canon 7D Mark II
50 1.0L IS| 85 1.0L IS | EF 10-1000L f/1.0 IS DO USM | 17-4000L IS | 24-7000L IS | 70-2000L 2.8 IS | Canon G12 | 580EXIII | 430EXIII
MarKap77
Mar 09, 2008 08:27 as a reply to  @ CJinAustin's post |  #3
Suggested reading. Click here (external link).
Mark
My Gear List
"I don't travel to get to work, travel IS my work!
sakurablossoms75
Mar 09, 2008 09:57 |  #4
ISO is max at 1600. And you are right, I do not know my camera good enough.
Thanx for your help..
Canon 5D2, Canon G9
DDCSD
GIVIN' GOOD KARMA
Mar 09, 2008 11:02 |  #5
sakurablossoms75 wrote in post #5076074 (external link)
Thanx in advance
Buy a tripod and set your ISO to 100, use the camera's timer to trip the shutter.
Derek
Bucketman Karma Fund
https://photography-on-the.net …php?p=9903477#p​ost9903477
POTN FF L2 MadTown Birds
Full Gear List & Feedback
andrewaaa5
Joined Sep 2004
Mar 09, 2008 11:36 |  #6
I have read here within this forum that if a tripod is used for long exposures, you should turn off the G9's image stabiliser. Apparently the image stabiliser is best for hand held work.
If you are doing long exposures with a tripod try your best to keep the ISO as low as possible also (as mentioned already above...)
andrew crighton
website -- > www.butterpeanut.com (external link)
flickr -- > flickr/photos/andrewaa​a5 (external link)
DDCSD
GIVIN' GOOD KARMA
Mar 09, 2008 11:42 |  #7
andrewaaa5 wrote in post #5078763 (external link)
You don't need the IS when used on a tripod, so its best to turn it off. Some EOS lenses actually perform worse with IS on when on a tripod, I don't know if this is the case with the G9 on not. The book should tell you. At the very least it will save you battery life.
Derek
CJinAustin
Mar 09, 2008 11:49 |  #8
DDCSD wrote in post #5078665 (external link)
This will give you the best results,,, Just keep in mind that anything that moves in the scene will still be blurry..
- GEAR -
Chet
Gallery: 132 photos
Mar 09, 2008 12:05 |  #9
And are you talking indoor or outdoor photography it makes a difference. What are you trying to capture? Indoors you can achieve focus by turning the lights on, outdoors you need something with enough contrast to lock your focus to. So a tripod is a must for your exposure.
lennythelens
Mar 10, 2008 10:39 |  #10
Use the flash! ;-)a
Regards,
Lennythelens
http://www.lennythelen​s.com (external link)
andrewaaa5
Joined Sep 2004
Mar 11, 2008 02:19 |  #11
lennythelens wrote in post #5085323 (external link)
Use the flash! ;-)a
haha. good one, but often flash ruins the mood of a nice softly lit scene. Good answer though :)
andrew crighton
sakurablossoms75
Mar 15, 2008 05:40 |  #12
FuryMe wrote in post #5078901 (external link)
Outdoor photos, trying to capture some skyline of London
Canon 5D2, Canon G9
DDCSD
GIVIN' GOOD KARMA
Mar 15, 2008 08:58 |  #13
sakurablossoms75 wrote in post #5119578 (external link)
See post #5.
Derek
labbai
Mar 16, 2008 17:41 |  #14
Used to take some night shots with my fathers F-1 using tri-x or pan-x pressed to ASA1200 max. tri-x was best in ASA400, but you could underexpose and overdevelope it to gayset the extreme out of it . Push processing they call it.Those were the <a href="http://www.kodak​.com/global/en/profess​ional/support/techPubs​/f4017/f4017.jhtml#pus​hprocessing:rollertran​sportprocessors">days...</a>
Canon, Gitzo, RRS, Zeiss, Pelenghttp://labbai.blogspot​.com/ (external link)
1,695 views & 0 likes for this thread, 8 members have posted to it.
1064 guests, 104 members online
