SheilaR wrote in post #5088674
I have a Rebel XTi and I know that I can shoot in RAW. The only problem is,I haven't done this yet and would like to try. I use CS2 for my editing and was wondering when I open up my RAW photos,where will it be listed in RAW format? I hope that I am not confusing anyone. I am just confused on if there is a different way to edit and/or open RAW format photos?
Sheila
Assuming that you have the proper camera raw update in CS2.
Open CS2
file->open (or) cntrl+o search for the raw file you wish to open. Then open the image. Now a different window will open up within CS2.
On the right you should have your histogram at the upper right and below the histogram you will have your settings section.
There should be a row of tab like so ADJUST/DETAIL/LENS/CURVE/CALIBRATE
Navigating through those tabs and adjusting the image to your liking is how you will edit you RAW file. Now on the bottom of the window you have your work flow options. SPACE, SIZE, DEPTH and RESOLUTION. From there you can convert your raw file to either a TIFF file, JPEG file and so on. 8bit-JEPG 16bit TIFF Image size and resolution are all up to you to decide. Once you are done editing the image save to to the proper destination and you are done. Now you can also edit multiple images as well in RAW.
I hope this helps you out. I have the Martin Evening CS2 book, i just looked at it and explained how the window is setup. It should be accurate.
Sevan
