Thread started 11 Mar 2008 (Tuesday) 07:08
microscopic pictures please help
Highlander1
Mar 11, 2008 07:08 |  #1
Hi All
I have got an interest in fibre technology and was looking at purchasing a microscope in order to examine carpet fibres via a usb onto a lap top computer so that i wouldn't have to remove fibres from ancient carpets for testing. I then thought about the possibility of connecting a microscope or device to my canon EOS 350D.
Does anyone have any ideas regarding this could it be done and if so what would I need to purchase. I really need 500x magnification so that i can view the scales on Wool fibres in particular.
Hope someone has some answers.
Cheers JB
www.brydens-craiglea.co.uk (external link)
LordV
Mar 11, 2008 07:14 |  #2
Hi- the highest realistic magnification you can get with a camera mounted lens is 5:1 with an MPE-65 lens - this gives a FOV width of 4.5mm with your camera which is obviously then blown up when viewing on a PC screen. Not sure this would be enough to see scales on the wool fibres though. Otheriwse think you are left mounting the speciment on a suitable microscope.
Brian V.
Macro Hints and tips
Jon
Joined Jun 2004
Mar 11, 2008 08:09 |  #3
Using a conventional microscope, you'd need to set up a tripod or copy stand to support the camera on a microscope adapter. You're looking at a high three or low four digit price, I think, and I'd really recommend getting a camera-ready microscope for the job. These will have a separate, vertical, ocular tube for the camera. Because it's vertical, you don't usually need a camera support with lighter cameras. However if you already have access to a microscope of suitable power you should be able to pick up an adapter for somewhere around $50, including a T-mount adapter.
Howevcer you do it, you'll want a right-angle finder as 1) you'll go crazy trying to see into the viewfinder with the scope on a tabl or bench and 2) you'll want the magnification available to enable manual focus with any degree of accuracy.
Jon
Cocker Spaniels
Highlander1
Mar 11, 2008 08:18 |  #4
Thanks for the replies so far So I am really looking at needing to purchase a camera adaptor and a microscope Brian do you know where I could view sample pictures using this type of lens.
JB
Pete
Mar 11, 2008 08:22 |  #5
Something like this?
http://cgi.ebay.co.uk …ZWDVWQQrdZ1QQcm​dZViewItem (external link)
Pete
UK SE Catch of the Day
LordV
Mar 11, 2008 15:38 |  #6
This might give you some idea - pic of an orchid petal taken at 4:1 with an MPE-65. You can see the individual plant cells which from memory are around 60microns in diameter.
Not sure what size your wool scales are ?
Brian V.
IMAGE: http://farm3.static.flickr.com/2204/2320734962_8f872756d6_o.jpg
Highlander1
Mar 11, 2008 17:31 |  #7
Incredible petal picture thanks everyone. I have been trawling the internet and been advised by a firm to send them some samples of fibres they will take the pictures using their equipment and return the images to let me see the result if it is OK. I will be looking at around £350s all in. How does that compare to the macro lens Brian.
Cheers JB
Pete
Mar 12, 2008 08:24 |  #8
LordV wrote in post #5095180 (external link)
Brian V.
Brian. Would the MPE-65 also work with extension tubes? I'm guessing that carpet fibres couble be mounted on a slide, so the DOF factor wouldn't be much of a player here.
Pete
1,672 views & 0 likes for this thread, 4 members have posted to it.
2423 guests, 103 members online
