Thread started 13 Mar 2008 (Thursday) 17:37
Cheap backdrop solution? (how to hang one?)
mike_wahl
Mar 13, 2008 17:37 |  #1
First off is it totally ghetto if im going to use a white bedsheet as a backdrop to do some just for fun self portrait shots? Assuming its acceptable, lol, what would be a quick and easy way to hang it so it would be straight and hang correctly?
Canon Rebel XT DSLR
Canon Speedlite 430EX Flash
Stock Canon EFS 18-55mm lens
Canon 75-300mm EF lens
Canon 50mm EF lens
BrianAZ
Mar 13, 2008 18:01 |  #2
Just get some clamps from home depot or Lowes. Silverlake give you a set of 2 $.96 clamps to hang up their $300+ backdrops. They work fine.
Website (external link)
My Blog (external link)
facebook (external link)
DSMITH131
Joined Jan 2005
Mar 13, 2008 20:23 |  #3
This is what I use on backdrops, reflectors and anything else I need to hang
http://www.lowes.com …-52800-XC-14PC&lpage=none (external link)
Daniel W. Smith Photography (external link)
Mayhem (external link)
Gear
mike_wahl
Mar 13, 2008 20:37 |  #4
Good ideas! I found a $3 clearance set of white sheets and some screwing hooks so Im going to attempt to hang it from the ceiling. I will give those clamps a try though if I could find something to clamp them too!
Canon Rebel XT DSLR
Canon 50mm EF lens
Titus213
Mar 13, 2008 22:36 |  #5
More than acceptable in my book. Staple it to the wall.....
Dave
Perspiring photographer.
Lotto
Mar 14, 2008 03:39 |  #6
Haha, Dave. Right now I have couple srews in the drywall, a 10' conduit hanging on them with coupld loops. Good things it's in the garage and nobody cares.
5D, 24-105L, 70-200L IS, 85mm Art, Godox
Lil' ­ Nikki
Mar 14, 2008 06:44 as a reply to  @ Lotto's post |  #7
You can get over the door hooks from some stores and then hang a pipe, broom handle, anything that will fit over the hooks with the sheets attached to it. That was you are not damaging any walls, ceilings etc.
-:- Lil' Nikki -:-
mike_wahl
Mar 14, 2008 08:39 |  #8
I just used two mug hooks into the ceiling and it served the purpose pretty well. The sheet just barely touches the floor so I think im going to maybe use something to hold it in place and make it a little more taunt. Its wrinkly but its so much easier to fix your background in PS when its one color!
Canon Rebel XT DSLR
Canon 50mm EF lens
thelightofsound
Mar 14, 2008 10:15 |  #9
i was just about to search for a similar thread, and here this one is on the front page. i bought a shower curtain rod at wal mart, so i could extend it between door frames or walls. i also picked up those exact clamps linked below but the for half the price. but i am still restricted to finding a spot where i use this set up and would rather have more of a support system. i was hoping the lowes link was going to include some cheap stands and a crossbar. does anyone know of a cheap solution for that type of setup?
DSMITH131 wrote in post #5111044 (external link)
--atlanta photographer michael saba (external link) - music photography (external link)
hawk911
Mar 14, 2008 10:18 |  #10
I'm sure any hardware store has wall hanging brakcets for rakes, etc that would extend a few inches past flush to the wall. Use that and a 10' piece of PVC, and use the shower curtain hanging clips to hang the sheet. You might have to cut some small holes (or use a paper hole puncher if it works) to put the holes in the sheet. Should be ghetto enough, and cheap.
HAWK Photography Gallery (external link) FB Fan page (external link)|_My gear: 5d3, 70D & 40D (all gripped), 580exII, 550ex, Canon 24-70 L & 85 f1.8, 50mm f1.4; Tamron 70-200 SP Di VC, Canon 18-55, Sigma 1.4xtc; Elinchrom Whore, Skyport triggers, Speedotron BD and Kacey Grid, Vagabond minis
MikeMcL
Mar 14, 2008 10:29 |  #11
thelightofsound wrote in post #5114305 (external link)
I dont know what your idea of "cheap" is, but BHPHOTOvideo has a nice portable set of (2) lightstands, and a 3-4 piece crossbar that will go to 12 feet. The whole thing in a carry bag is like $90. I had one and used it for a lightweight portable system to augment my more heavy duty one.
The other option is to go get a 10' length of PVC pipe and just hang a string from the cieling in 2 places at the ends of it. That option will run about $11.
Keep in mind that you folks with the bedsheets can take it to a dry cleaner or seamstress and have them sew a long pocket at one end of it. Normally this costs about $6-$8... and it will end a few of the headaches. Maybe you try your luck on a friends sewing machine, and do it for free, who knows.
Good luck
350d, 5d, 28-70L, 70-200L, 430EX,
50 1.8, 85 1.8 - full alienbees studio set.
MikeMcLane.comexternal link
cavfan06
Mar 14, 2008 10:43 |  #12
Check out these stands...
http://www.amvona.com …ge&view=1&produ​ct_id=3058 (external link)
not a bad price..
Brian
mike_wahl
Mar 14, 2008 11:23 |  #13
In my case, I dont have a 'free wall' to hang the sheet in front of, so I had to suspend it in the center of the room. With a king size sheet though, that thing nearly spans the width of the room so theres a lot of room to work with. I picked up three $6 black and decker lanterns to use as some cheap lights. Slapped some wax paper on em to diffuse the light and it made a nice cheapo setup.
I like the PVC suspended setup though, it could allow me to let the sheet hang on the floor a little for some sitting shots. I may pick up an extra white sheet to do that with though.
Canon Rebel XT DSLR
Canon 50mm EF lens
bishop13
Mar 14, 2008 12:11 |  #14
I've used painter's tape to hang my "background" (aka, queen sized sheets). Clean, quick, and portable ;)
lowcrust
Mar 14, 2008 12:28 |  #15
I got what is called a wet-sheet from a friend working in air-cargo. It's put between the pallet and the goods (that can sometimes be wet). It's just paper but it's heavy duty and it's slightly wavey so when out of focus it's got an ethereal feel to it.
I've three metal enforced holes so that I can hang it on the wall. Some day I might try to make it roll up and down for easier storage.
~ BORN FREE - TAXED TO DEATH! ~
20,127 views & 0 likes for this thread, 22 members have posted to it.
2709 guests, 151 members online
