Thread started 01 Nov 2004 (Monday) 15:44
50 1.8 & 550EX
DReb-MO
Joined Apr 2004
Nov 01, 2004 15:44 |  #1
I was trying to use my "nifty fifty" and 550EX last night to take pics of the trick-r-treaters and ran into a problem. I had the 550EX set to auto and ETTL and got nothing but SLOW shutter speeds at 1.8. I tried and number of differing stops and generally got the same result each time. When I couldn't figure out what was going on I changed to the 28-135 IS lens and it worked fine. Did I miss something with the 50? Thanks.
Canon 40D w/BG-E2N & EP-EX15
70-200mm f/2.8L IS, 24-70mm f/2.8L, Extender 1.4x II, 18-55mm f/3.5-5.6, 50mm 1.8 II, Speedlite 550EX, Bogen 3221 Tripod & 3047 Head, Bogen 3245 Monopod & 3229 Head, Canon i9900
daveh
Joined Apr 2003
Nov 01, 2004 16:00 |  #2
Yes, don't use auto modes in the dark if you want fast shutter speeds and small apertures. In auto modes the 550 does it's best to balance the flash with the ambient lighting.
Reminisce
Joined Sep 2004
Nov 01, 2004 17:52 |  #3
What he said. If using the flash, shoot in one of the creative modes, preferably M, or Tv myself.
scottbergerphoto
Joined Jun 2003
Nov 01, 2004 17:53 |  #4
The camera tries to meter for the ambient light as if there was no flash. In P mode, Canon cameras have a limit of 1/60 sec. In Av, and M, there is no such limit. The camera will slow the shutter speed to capture the available light. The 10D has a CFn. that allows you to set a minimum floor of 1/200 in Av mode. This has nothing to do with lens choice other then faster lenses can open up more and give you faster shutter speeds in low light.
Scott
One World, One Voice Against Terror,
Best Regards,
Scott
ScottBergerPhotography (external link)
Headcase650
Joined Jun 2004
Nov 01, 2004 18:43 |  #5
I was in the same situation last night. Did some playing around, Set the camera to manual, shutter to 250/second, 550ex on high speed sync, ISO 400, then adjusted the apiture till I got a fair looking pic and histogram.
60D, Canon 18-135 IS, Sigma 10-20 hsm, 24-70 2.8 hsm, 70-200 2.8 hsm, 430EX II, and all the other stuff that goes along with it.
DReb-MO
Joined Apr 2004
Nov 02, 2004 05:11 |  #6
Thanks..
I was using creative modes and not any of the auto modes. If I recall I tried both Av and Tv. All I did was switch lens's and the combination worked fine with the second lens, the 28-135 IS. Anyway, thanks again.
daveh
Joined Apr 2003
Nov 02, 2004 08:50 |  #7
Those are auto modes. Try "M".
DReb-MO
Joined Apr 2004
Nov 02, 2004 10:27 |  #8
The Creative Modes are Auto? That's a new one to me. I suppose I will have to use "M" with this lens and see what happens. As I went back through my notes and this forum I realized that the "nifty fifty" is one of the lenses in the EF lineup which don’t have distance data and therefore does not communicate with the flash.
Too much information to remember...
daveh
Joined Apr 2003
Nov 02, 2004 10:59 |  #9
That's kind of a trick question because I believe "M" is also labeled a "creative mode". So there are automatic and manual creative modes.
The way cameras get more and more automated, someday giving the user a choice of where to point the camera and when to fire the shutter will be called a "creative mode" ;)
But yes, "M" stands for manual, and the things that are not manual are automatic. Some have more degrees of automation and less user input than others.
Distance info shouldn't be an issue in a case like this.
1,629 views & 0 likes for this thread, 5 members have posted to it.
50 1.8 & 550EX
2498 guests, 103 members online
