Thread started 02 Nov 2004 (Tuesday) 23:52
white balance
biggin
Joined Feb 2004
Nov 02, 2004 23:52 |  #1
when shooting indoors with my g3 what white balance setting should I use if I am using a 420 flash? flash or automatic or flouresent white balance setting since the place has flouresent lights that I will be shooting in.
Andy_T
Joined Jan 2003
Nov 03, 2004 02:46 |  #2
Best advice would maybe be to shoot in RAW mode ... then you could change the WB afterwards.
Shooting indoors with flash can be tricky ... the flash illuminates the subject (so flash would be ok), but the back is illuminated by Tungsten, halogen or other lights ... one of the two will most likely be off.
Best regards,
Andy
some cameras, some lenses,
and still a lot of things to learn...
(so post processing examples on my images are welcome :D)
If you like the forum, vote for it where it really counts!
CLICK here for the EOS FAQ
CLICK here for the Post Processing FAQ
CLICK here to understand a bit more about BOKEH
sdommin
Joined Dec 2002
Nov 03, 2004 08:50 |  #3
You should use "daylight" (or sunny) WB, because that's the color of the light coming out of your flash. Most cameras will automatically change the WB for you when you turn on the flash (not sure about external flashes, though).
Scott
http://www.pbase.com/s​dommin/favorites (external link)
S45_fornow...
Joined Dec 2003
Nov 03, 2004 10:02 |  #4
The G5 has a white balance setting for "Flash". Not sure if G3 has it also.
biggin
Joined Feb 2004
Nov 03, 2004 15:20 |  #5
white balance
yes my g3 has a flash setting for white balance so would this be the best choice for using an external 420 flash. I do not want to shoot in raw. jpegs are what I need to use. any and all help would be helpful.
S45_fornow...
Joined Dec 2003
Nov 03, 2004 16:02 |  #6
i would experiment some with the different wb settings for use with your external flash. heck, the worst thing that could happen is you end up with some bad shots that are easily deleted from your cf card.
i did find that the wb setting for flash worked fairly well with my g5.
now go shoot some pics and enjoy your camera.
joeyjoeyjoey
Joined May 2004
Nov 04, 2004 16:43 |  #7
I agree this is the only way to shoot.
I see in bokeh. (external link)
1,416 views & 0 likes for this thread, 5 members have posted to it.
white balance
2268 guests, 130 members online
