Thread started 18 Mar 2008 (Tuesday) 07:25
Jpeg size in camera vs. Raw to Jpeg in DPP
John ­ E
Mar 18, 2008 07:25 |  #1
I just noticed that when I convert raw pictures to large Jpegs in DPP the file size is approximately 7-8 megs. When I shoot large Jpegs on my 30D they are 3-4 megs in size. Why the difference? Is is more beneficial to shoot all raw then convert to Jpeg through DPP? In other words, will the larger Jpeg file from DPP give you more lattitude in post-processing?
John Elser
Canon 5D MK II; 30D; EF 85 f/1.8; EF 70-200L f/2.8 IS II; EF 24-105L f/4; EF 135L f/2; EF 24-70L; Canon 580 EX II(x3).
cdifoto
Don't get pissy with me
Mar 18, 2008 07:27 |  #2
Set the DPP converter to about 6-8, which is about the equivalent to what the camera is doing and you'll notice similar file sizes.
In other words, the camera is compressing more (throwing away more data) than the RAW converter does when set to max.
cfcRebel
Mar 18, 2008 09:13 |  #3
John E wrote in post #5139256 (external link)
Preferably, do all the adjustments in DPP before converting to jpeg to minimize data loss.
Fee
Canon | SIGMA | TAMRON | Kenko | Amvona
Max ­ F
Mar 18, 2008 11:59 |  #4
The fine jpg on the xti is equivalent to 8 in DPP. I verified using a program - I can't think of the name and its on my home computer. Anyway, the output was 98 (fine jpg) and 97 (8 in DPP). Thats as close as I could get it. The size is around the same although DPP is a little larger file due to the extra noise (in camera uses noise reduction).
Oh and the larger size will only assure you will not have compression artifacts. It should be said that I have yet to see compression artifacts using fine jpg in camera. So just set DPP to 8 and save (after you make all of your adjustments).
Max ­ F
Mar 18, 2008 12:05 |  #5
Oh, I found it. The tool is JPEG quality estimator
http://www.mediachance​.com/digicam/jpgq.htm (external link)
1,865 views & 0 likes for this thread, 4 members have posted to it.
500 guests, 126 members online
