I have a chance to buy a used 600mm f/4.5L (FD mount) for less than $1,000. Believe it or not, it used to belong to one of the local police departments. It is in beautiful shape with just a couple small paint nicks. The glass looks real perfect.
I bought one of the cheap FD-EOS converters, and took a couple test shots with it this afternoon
As you might expect. it is purely a manual lens. I took the test shots using Fv, and it seemed to work okay, although I also had to meter manually.
I estimate the distance to the car to be approximately 200 feet, so I still don't know if this lens will focus to infinity. I'm not too concerned about that because I would rarely have need for that capability.
The image quality is so so and there is some CA on vertical lines, but not too bad. It is reasonably sharp, but could be better I feel. Canon did make a converter that would no doubt be optically superior to the cheapy converter I'm using, but they didn't make very many of them, and they are almost impossible to find.
I guess what I'm asking all of you is your opinion of whether or not this lens (with it's current limitations) is really worth $900 or not. It will never be a sports lens.....everything is manual and time-consuming. I will never take a quick shot with this setup. On the other hand, it seems like it works reasonably well in situation where I have plenty of time to set up, manually meter the shot, focus, and take it.
I can see already I need a better head for my tripod with this beast. I suspect I'll get a gimbal mount if I decide to keep it.
This is the lens and case:
![]() | HTTP response: 404 | MIME changed to 'text/html' | Byte size: ZERO |
This is the view towards the car I used for the test. This was shot at about 120mm with my 70-300DO, so the car appears closer than it actually was. I estimate 200 ft.
This is the full image taken with the 600mm
And this is a 100% crop of that image.
I value your opinions.
