Does anyone know if the Canon 70-200 mm f/2.8 IS will fit inside any of the lowepro slings? Also does anyone know about other manufactures that make sling type camera bags? Thanks
mike_85 Mostly Lurking 19 posts Joined Apr 2007 More info | Mar 19, 2008 21:41 | #1 Does anyone know if the Canon 70-200 mm f/2.8 IS will fit inside any of the lowepro slings? Also does anyone know about other manufactures that make sling type camera bags? Thanks Rebel xti, grip, canon ef 50 f/1.4, canon ef 17-40 L, speedlite 430, rebel t2
LotsToLearn Goldmember 2,290 posts Joined Mar 2007 Location: GTA, Canada More info | Mar 19, 2008 21:53 | #2 It fits easily in the 300AW and can fit in the 200AW if you reconfigure the inserts.
patrick835 Goldmember 1,033 posts Joined Feb 2008 Location: Orlando, FL More info | Mar 19, 2008 21:58 | #3 it will fit the 300 1D mk II + sigma 10-22 + 100f/2.8 + 70-200/f4L + f/2.8L IS II+ tamron AF 2x + 430EX II
LotsToLearn Goldmember 2,290 posts Joined Mar 2007 Location: GTA, Canada More info | Mar 19, 2008 22:30 | #4 Patrick835, I've put my 20D with 70-200 2.8 IS attached in the 200AW width-wise. But it's extremely tight, nearly uncloseable and creates alot of bulging, so I don't use it for that. Others have also posted pics of it inserted along the height but I prefer not to reconfigure the inserts to accomplish that.
FlyingPhotog Cream of the "Prop" 57,560 posts Likes: 178 Joined May 2007 Location: Probably Chasing Aircraft More info | Mar 19, 2008 22:36 | #5 I can get a gripped 5D with either the 70-200 f/2.8 or the 100-400L in the 300 with the hood reversed. Fits best if you turn the camera 90 degrees counter clockwise so the left side of the body (viewed from the rear) faces the back of the bag. Jay
snails "I used the last of it to tip the strippers." 1,517 posts Joined Jan 2008 Location: Ann Arbor, MI More info | Mar 19, 2008 23:13 | #6 |
| Latest registered member is IoDaLi Photography 1402 guests, 141 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
