Thread started 20 Mar 2008 (Thursday) 12:30
UV Filter to Complete Weather Sealing??
drjiveturkey
Mar 20, 2008 12:30 |  #1
I've read on the-digital-picture.com that you needed a UV filter to complete the weather sealing on some of the L lenses.
16-35 II & 24-70 are ones that I have.
I'm not one that likes using filters but thought of buying some to complete the weather sealing now that I have a 1Dmk3
I decided to call Canon Customer Support and the rep said that those lenses are seal as long as it's on a 1D series and no filter was needed. Of course he was just reading off the discription of the lens.
Can anyone shed some light on this subject? Have you read in any Canon Manual that it says weather sealing is dependant on the filter?
It all started as a hobby with a Rebel XT & KIT lens. $5K worth of equipment & $0 of income later, all I have to show for it is a harddrive full of pictures and priceless memories!! Yeah it's still worth it :)
baybud
Joined Feb 2006
Mar 20, 2008 12:37 |  #2
drjiveturkey wrote in post #5155404 (external link)
The 17-40mm L manual does (or did) say that a filter is needed to complete the weather sealing.
On a different note what sort of filters have you been using? I use a B+W (not to bad) and a hoya pro 1 (very very good)
I find with my 85L there is no difference between IQ with the Hoya filter on even if viewed at 800%+
The B+W on the other hand i can notice differences at about 400% only.
Personally i think if you can get a good filter its seriously worth getting, don't get me wrong i wouldn't use it if it degragded IQ, but there are alot of good filters around these days.
Personally i'd stick to the Hoya Pro 1 B+W terribly over priced and not as good as them IMO
drjiveturkey
Mar 20, 2008 13:05 |  #3
I use B+W polarizers but don't like to use UV filters all the time for protective purposes because of what happened to my 24-70 2.8.
I had a B+W 77mm MRC filter on it for "protection" and had the lens and camera in a small padded camera pouch (just big enough to fit the camera and lens). The pouch fell out of my car about 6inches onto asphalt and the Filter was Cracked down the middle!
I was thinking to myself, crap what if that were from a higher distance or without the padded case. That filter would have shattered and may have scratched the front element! So no more "protective" filters for me for everyday use. I'll only use it when I need weather sealing but theyn I just thought, do I even need it for that?
argyle
Mar 20, 2008 13:16 as a reply to  @ drjiveturkey's post |  #4
Have you read your lens manuals?...IIRC, my 17-40L manual mentions that specifically. I would imagine that the manuals for your lenses would also.
drjiveturkey
Mar 20, 2008 13:28 |  #5
I haven't look through the manual yet. When I get home from I'll do that and post the results. I never even thought to look untill now.
ed ­ rader
"I am not the final word"
Mar 20, 2008 13:36 |  #6
drjiveturkey wrote in post #5155767 (external link)
that's usually the last place i look too :D.
ed rader
5D4, 80d, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, sigma 15 FE, sigma 14 f1.8 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
drjiveturkey
Mar 20, 2008 13:48 |  #7
ed rader wrote in post #5155811 (external link)
ed rader
I can't even remember the last time I've read the operation manual to anything
nicksan
Man I Like to Fart
Mar 20, 2008 13:52 as a reply to  @ drjiveturkey's post |  #8
I wouldn't give B+W filters a bad rap. Make sure you buy the MRC 010 F-Pro versions. They are fine.
But then again, I'm not sure if OP is going to view images at 400%-800%.:confused:
ethan_esrah
Mar 20, 2008 16:05 |  #9
Here's what the 16-35/2.8 II manual says:
Although the lens is dust- and water-resistant, a Canon filter must be attached to the front of the lens for complete protection. Unless a protective filter is attached, the dust- and water-resistant features are not assured.
I kicked off a similar discussion (for the 16-35 II) in a German forum a couple of days ago. As always when it comes to filter use the opinions were divided. Most respondents stated that they would rather take the risk of a leaking lens than of reduced IQ. Unfortunately, noone was able to describe the difference of dust/water-resistance with filter on vs. off. But exactly this would be the information on which I would like to base my decision. If the lens could stand some light rain for a couple of minutes as well as the "usual" dust in the outback I would not worry about a filter. After all, my EOS 5D might be the weaker element when it comes to water and dust, not the lens.
Cheers, Sven
Canon: EOS 5D Mark III, EOS 5D, EOS 300D, 16-35/2.8L II, 24-105/4L, 50/1.4, 100/2.8 Macro, 100-400/4.5-5.6, Speedlite 420EX | Others: Manfrotto MA 055 CLB + 141 RC, some Richter studio flashes
baybud
Joined Feb 2006
Mar 20, 2008 16:29 |  #10
drjiveturkey wrote in post #5155617 (external link)
:O yeah but in that situation the lens would be even worse off!
I understand what your saying though, personally though i think there are far more instances where a protective filter does what it is intended than instances where it does the opposite.
steved110
Mar 20, 2008 18:15 as a reply to  @ baybud's post |  #11
I use filters to protect my lenses from dirt , not accidents.
I use insurance to protect myself from accidental damage to the lenses.
I use hoods to minimise flare, not as bumpers.
Canon 6D
Canon EF 50mm f/1.4 , Canon EF 85mm f/1.8 Canon EF 100mm f/2.8 macro
CanonEF 17-40 f/4 L Canon EF 24-70 f/4 IS L and 70-200 f/4 L :D
Speedlite 580EX and some bags'n pods'n stuff
drjiveturkey
Mar 20, 2008 18:18 |  #12
steved110 wrote in post #5157570 (external link)
Exactly. That's why I only put on UV filters on when I need the weather sealing. Other times it just increases the risk of damaging the front element if it ever shatters.
drjiveturkey
Mar 21, 2008 21:23 |  #13
I checked the manuals for which lenses need filters to complete the environmental/weather sealing:
16-35 II Yes
24-70 2.8 No
70-200 f/4 IS & f/2.8 IS no
sheawyatt
Mar 21, 2008 21:30 |  #14
ethan_esrah wrote in post #5156711 (external link)
Cheers, Sven
I thought it was fairly obvious with the 16-35 and 17-40. . . the front element moves when you zoom, so there is no protection around the front element unless you have a filter. The 24-70 and 70-200 IS all have stationary front elements, so they get the weather sealing built right in.
EOS R5 | RF 15-35 f/2.8 | RF 24-70 f/2.8 | RF 70-200 f/4 | EF 400 f/4 DO II | EF 1.4x III |
Marketplace Feedback: Link
www.sheawyatt.ca (external link)
Choderboy
I like a long knob
Gallery: 185 photos
Mar 21, 2008 22:57 |  #15
sheawyatt wrote in post #5164549 (external link)
I think you have been ripped off with counterfeit lenses. :)
Dave
Image editing OK
3,726 views & 0 likes for this thread, 11 members have posted to it.
Latest registered member is Cutiepiewee
1127 guests, 126 members online
