Thread started 06 Nov 2004 (Saturday) 11:43
G6 lens filter
bosamar
Joined May 2004
Nov 06, 2004 11:43 |  #1
Is it possible to place a lens filter on the G6 lens? And if so what size/recommendations?
Kodak DC260/Canon S200/Canon A95/Canon G6/Canon SD1100 IS
"I was gratified to be able to answer promptly and I did. I said I didn't know." - Mark Twain - Life on the Mississippi
jimsolt
Joined Apr 2004
Nov 06, 2004 20:34 |  #2
It is possible to attach a filter to the conversion lens adapter, thus filtering the standard camera lens. To the best of my knowledge, neither the tele-converter nor the wide converter lenses are threaded to accomodate a filter. The size would be 58mm.
bosamar
Joined May 2004
Nov 06, 2004 20:58 |  #3
I guess I better check out the conversion lens adapter. Thanks for the info!
MrChad
Joined Aug 2004
Nov 06, 2004 21:27 |  #4
Can you place the filter between the lens ring and the access. lens on the front?
Seams like this would be ideal for a polarizer?
The G6 lens can't zoom past the adapter ring can it?
I kaNt sPeL...
[Gear List]
sdommin
Joined Dec 2002
Nov 07, 2004 06:19 |  #5
As has been stated, you need an adapter to be able to put a filter on your G6. Note that the adapter is different from the one that fits the G3 or G5. Lensmate is a highly regarded company that is getting ready to offer 2 versions of the adapter, in 52mm and 58mm sizes. Read about it here:
http://www.lensmateonl​ine.com/new.html (external link)
You can also buy the LA-DC58D adapter made by Canon. It's 58mm only. Here's some info from B&H's web site;
http://www.bhphotovide​o.com …ails&Q=&sku=348​412&is=REG (external link)
Scott
http://www.pbase.com/s​dommin/favorites (external link)
bosamar
Joined May 2004
Nov 07, 2004 07:46 |  #6
Thanks for the info sdommin. Looks like I'm going to make a purchase.
Superbaldguy
Joined Sep 2004
Nov 07, 2004 16:26 |  #7
Yikes!
Good thing I have some friends who own a photo store and can get me that adapter for almost cost price...........
bosamar
Joined May 2004
Nov 07, 2004 21:24 |  #8
Speaking of good deals, I got a 1GB Lexar 40x CF today for $79.99 and a $20 rebate at Fry's in San Diego.
dbump
Joined Apr 2003
Nov 08, 2004 12:53 |  #9
Two concerns with stacking a conversion lens on top of a filter:
First, If the filter is a polarizer, it's possible for the outer rotating ring to separate from the ring that's threaded to the camera/adapter tube when it's stressed by the weight of a big chunk of glass.
Second, with any filter (or especially with multiple filters) it's possible you'll see vignetting. Basically, the further from the camera the conversion lens is, the smaller the "tunnel" gets. Hold a ring up to your eye, and then move it away to see this effect. Anything outside the ring is going to be black in your image--you'll see it first in the corners, of course, because they're cropped by a diminishing circle sooner than the edges are.
Actually, the latter is a potential issue even if you get a non-Canon conversion lens that is threaded for filters--you're still moving that circle further from the camera. One thing you could do, however, is get a step up ring, and larger filters--basically extending the cone shape of the conversion lens, so that you're staying out of the light path. But larger filters are more expensive...
I don't know how close the G-6 is to vignetting with just the adapter and a conversion lens--there may be enough play there for you to get away with it?
MrChad, the Canon adapter (as well as the Lensmate) is designed with that use in mind, so I'm sure the lens does not extend past the end of the adapter. This is the case with my G2 and Canon's adapter--I use filters on it all the time.
7D, G10, 17-55 f/2.8 IS, 70-200 f/2.8 IS, 100 Macro, 50 f/1.4, 430EX II
There are no wrong notes
--Thelonious Monk
1,623 views & 0 likes for this thread, 6 members have posted to it.
G6 lens filter
2267 guests, 130 members online
