Windows Explorer won't show thumbnail pictures of G9 raw files. It does fine for my 20d. I imagine it's just because the G9 is newer and Microsoft hasn't caught up.
Does anyone have any info as to a fix or when a fix might come?
Thanks.
Mar 21, 2008 16:45 | #1 Windows Explorer won't show thumbnail pictures of G9 raw files. It does fine for my 20d. I imagine it's just because the G9 is newer and Microsoft hasn't caught up. Doug Sturgess
TPG Member 126 posts Joined Feb 2008 Location: OTW More info | Mar 21, 2008 16:46 | #2 Canon raw plugin.
Pete I was "Prime Mover" many years back.... 38,631 posts Likes: 25 Joined Jul 2006 Location: Berkshire, UK More info | Mar 21, 2008 16:49 | #3 |
LotsToLearn Goldmember 2,290 posts Joined Mar 2007 Location: GTA, Canada More info | Mar 21, 2008 16:58 | #4 It will depend on which version of Windows you're running.
Mar 21, 2008 17:50 | #5 LotsToLearn wrote in post #5163238 It will depend on which version of Windows you're running. XP SP2 natively doesn't support it but you can try to install the Windows Imaging Component (WIC) update and then the Canon RAW Codec and you may get support for it but I'm not sure if Explorer is a WIC enabled application under XP yet. MS also had a power tools plug in that provided previews of some older RAW formats but it's an unsupported plug in and isn't being upgraded. Vista out of the box should support it as long as you still install the Canon RAW Codec. WIC is built into Vista. I'm running XP Professional. Your explanation make sense to me. I already had WIC & the RAW codec installed. Explorer only shows RAW picture thumbnails of my 20d, not my G9. Doug Sturgess
KeithR Goldmember 2,856 posts Likes: 1 Joined Aug 2006 Location: Blyth, Northumberland, NE England More info | Mar 21, 2008 20:10 | #6 |
condyk Africa's #1 Tour Guide 20,887 posts Likes: 22 Joined Mar 2005 Location: Birmingham, UK More info | Mar 22, 2008 02:21 | #7 Use FastStone Image Viewer ... it will view your RAW's and import them to folders as required and allows renaming of files in a sensible way and much more. With a quick right click it'll open your file in PS or whatever you use. Seamless. Oh, and it's free https://photography-on-the.net …/showthread.php?t=1203740
KeithR Goldmember 2,856 posts Likes: 1 Joined Aug 2006 Location: Blyth, Northumberland, NE England More info | Mar 22, 2008 09:29 | #8 OP wants to see 'em in Windows Explorer, Dave - Arcsoft RAW Thumbnail Viewer will do that, Faststone won't.
condyk Africa's #1 Tour Guide 20,887 posts Likes: 22 Joined Mar 2005 Location: Birmingham, UK More info | Mar 22, 2008 09:48 | #9 That's fine, I understand ... I just suggested what I think is a better alternative to Explorer. Now he can choose his best solution https://photography-on-the.net …/showthread.php?t=1203740
| Latest registered member is Niagara Wedding Photographer 1238 guests, 118 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
