Thread started 06 Nov 2004 (Saturday) 16:39
EOS 20D Sensor Bad after ONLY 10 Days HELP!!
altfineart
Nov 06, 2004 16:39 |  #1
I could really use some help! I have had a Canon EOS 20D for 10 days and purchased it at B&H Photo. Well I was out shooting a bridge with a bright sky today and ALL of the images came up with a black spot. It showed up in the same EXACT spot in the upper left quadrant of all the images. I checked my invoice B&H only takes Digital cameras back for 7 days. I called Canon and did everything they told me; cleaned the sensor, the contacts, the lens, etc and STILL THAT STUPID BLACK SPOT. Now they tell me my only option is to mail it back to them at the factory and in a few weeks (maybe longer is what I am thinking) I'll be getting it back. They won't give a credit for the the time they have it back towards the warranty so basically I be losing a month or more of my warranty! I guess I'm asking all of you that have this camera, is what are my options? Is there somethign else I can try to get rid of the black spot or am I just stuck with sending it back to them to have them mess around inside and then send a highly sensitive electronic back to me minus a month of my warranty and hope they haven't screwed something else up?
defordphoto
MKIII Aficionado
Joined Oct 2002
Nov 06, 2004 17:02 |  #2
It's a stubborn piece of dust. Not a big thing. Post a sample photo.
defordphoto | Celebrating the art of photography®
SD500, 10D, 20D, 30D, 5D, 1DMKII, 1DMKIII
www.ussbaracing.com (external link) | www.rfmsports.com (external link) | www.nwfjcc.com (external link)
An austere and pleasant poetry of the real. Ansel Adams
robertwgross
Joined Nov 2002
Nov 06, 2004 17:21 |  #3
It could be a piece of dust, and that will be cleanable. It could be an actual fault in the sensor, although that would be somewhat rare, so Canon would replace the entire camera if they saw that.
Did you try a proper technique for sensor cleaning?
---Bob Gross---
altfineart
Nov 06, 2004 17:35 |  #4
As requested here is a sample image. You can see the black spot in the upper left quadrant of the image in the blue sky. I should note that I have cleaned the sensor as instructed by the Canon Help people on the phone ( I also cleaned it following the instructions in the manual) and this did not fix the problem. Is there another way to clean the sensor that will not hurt it and will keep me from having to send it back to them for a month?
Radtech1
Everlasting Gobstopper
Joined Jun 2003
Nov 06, 2004 17:42 |  #5
Take 2 shots of the same thing. Take one at the lowst f-number your lens will allow, and one at the highest. (OF COURSE, adjust the exposure time to compensat. If the spot is not there on the low f shot, but is there on the high f shot, it is something ON the sensor. Most likely dust, or some other particle. That would be good news, indicating that the sensor is not bad. Then just a matter of cleaning.
Rad
Be humble, for you are made of the earth. Be noble, for you are made of the stars.
altfineart
Nov 06, 2004 19:09 |  #6
20D Sensor Woes SOLVED! THANK YOU
Ok the idea of the f-stops showed what was going on so now I know its dirt. What I want to know is why didn't Canon suggest that? I have done a simple clean and improved it somewhat and next week I'll look up a local shop with someone that has the proper equipment that I can walk into with it and wait while they clean it. Thank you for the information I might actually get some sleep tonight! Was thinking $1500 gone and Canon didn't help with their attitude.
Persian-Rice
Joined Apr 2004
Nov 06, 2004 20:35 |  #7
After 10 days, you have that much dust? wow.
I take 2000 pictures a week and I don't get that much dust in 3 months.
BTW, just for the hell of it, clean the front and back elements of your lens with something like silk/polyester eyeglass cleaning cloth.
That one on the top left is not your only problem, it appears as if you have dust all over the place.
defordphoto
MKIII Aficionado
Joined Oct 2002
Nov 06, 2004 21:42 |  #8
altfineart: Yup. That's dust. Get one of these:
IMAGE: http://www.bhphotovideo.com/images/items/259157.jpg
At: http://www.bhphotovide​o.com …ails&Q=&sku=259​157&is=REG (external link)
phili1
Joined Oct 2003
Nov 06, 2004 21:45 |  #9
I agree it looks like lens dust.
When you change lenses make sure you hold the Camera body down.
If it is dust on the sensor you need a rocket blower but read the sensor clenging instructions carefully. A local camera store will not touch it because they are affraid of voiding the warrantee.
MKII N-Canon 20D - Tamron 90MM F2.8 Macro -
Tamron 17-35 F 2.8-4 - Canon 70-200 F4 L
Canon 100-400 F4.5-5.6 IS L - Kenko Pro 300 Ext 2 X - 420 EX
DocFrankenstein
Joined Apr 2004
Nov 06, 2004 22:32 |  #10
WOW. That's dirty!
National Sarcasm Society. Like we need your support.
tpinchback
Joined Jan 2004
Nov 06, 2004 23:23 |  #11
My 20d right out of the box looked like it had been through a sand storm with no lens attached. Why dont they clean the sensor before shipping??
1D MKIII 5D MKII
Glass ranging from 16mm to 400mm
commando
Joined Oct 2004
Nov 07, 2004 01:52 |  #12
My 300D was perfect when I got it.
There's a thread somewhere around here that points to a very, very good tutorial about cleaning your sensor, hopefully someone can point you at it.
drisley
"What a Tool I am"
Joined Nov 2002
Nov 07, 2004 02:04 |  #13
http://www.pbase.com/c​opperhill/ccd_cleaning (external link)
EOS R6 Mark II - Sigma 50/1.4 Art - Sigma 14-24/2.8 Art - Canon EF 70-200/2.8L Mark III - Godox Xpro-C - Godox TT685C x2
dhbailey
Joined Oct 2004
Nov 07, 2004 04:29 |  #14
On Thursday I started noticing 3 very faint spots on my pictures, always in the same places. I immediately cleaned my lens and then I realized the spots were there in pictures I had taken with two different lenses so I realized it was spots on the sensor.
I went to a local camera shop and purchased the rocket blower and it took me 4 separate times cleaning the sensor with that, taking a picture of the sky, looking at it on my computer and repeating the process before all the spots were gone.
I have ordered that cleaning kit from Copper Hill for any more stubborn spots in the future, but I am not sure I will follow his suggestion to clean the sensor every week or two. I figure I will clean it when it shows spots. I shoot enough pictures of the sky to notice immediately when the spots show up.
David
Cameras: S3is and 20D
Canon 18-55 kit lens, 50mm 1.8, 75-300 USM IS
Tamron 28-75 F2.8, 420EX flash
phili1
Joined Oct 2003
Nov 07, 2004 04:49 |  #15
Drisley have you used it yet. I used his specs and built one but have not had the need to use it.
3,486 views & 0 likes for this thread, 12 members have posted to it.
2565 guests, 94 members online
