Thread started 22 Mar 2008 (Saturday) 02:37
Manfrotto 055MF or Feisol CT-3371
Rey
Mar 22, 2008 02:37 |  #1
I'm not looking for so much a lightweight tripod as much as a more rigid tripod. ATM, I own a Manfrotto 3001 with a 488RC2. I thought I had a pretty rigid setup until I got my 40D and started using live view with my 70-200mm. Using manual focus the thing jiggles like jello and makes it difficult to get focus (once I remove my had it stabilizes nicely). I thought it was the norm since this is the most stable tripod I've ever owned... That is until my buddy let me use his GItzo GT3530 with RRS B55 LR ballhead from work. While it was susceptible to shake as well it was MUCH less than my setup. I had already ordered a RSS LR II clamp so I called RRS and had them cancel that and send me the B55 LR ballhead instead (I wanted it mostly for the L bracket). While I would like the Gitzo tripod there is no way I can justify paying that much.
So, no $600+ tripod for me :( I've set my limit at around $300-$350 for the tripod legs. For those who have had experiences with carbon fiber legs what would you pair with the RRS B55 ballhead? I've narrowed it down to two choices. The Manfrotto 055MF and the Feisol CT-3371. I'm leaning towards the Feisol but I trust the Manfrotto brand. Thoughts?
Canon 5D MKII • BG-E6 • Canon EOS-M • Canon 85mm F1.2L II USM • Canon 100mm F2.8L Macro IS USM • Canon 16-35mm F2.8L II USM • Canon 24-70mm F2.8L USM • Canon 70-200mm F2.8L IS USM • Sigma 50mm F1.4 ART • Canon Speedlight 600 EX-RT • Canon Speedlite 580EX II • Canon Speedlite 430EX II • Gitzo 3530 • Really Right Stuff BH-55 LR
argyle
Mar 22, 2008 07:38 |  #2
Its probably a toss-up between the two. The Feisol, IIRC, is rated for a heavier load. But either way, I hope you don't plan on doing much hiking...each of those tripods, with the RRS BH-55 head attached (2#), will weigh in at about 7 pounds. My assumption is that you have the gear that requires such heavy-duty support (it may be overkill for the 40D/70-200 that you mentioned). If not, there are better, lighter, and less-expensive options available.
René ­ Damkot
Mar 22, 2008 12:55 |  #3
Wait until you get the ballhead.
I suspect the Arca vs. RC2 QR might make quite a difference...
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
jhom
Mar 22, 2008 14:06 |  #4
I had the 055MF3 for a couple of years. It is a solid CF tripod and affords the versatility of a horizontal center column. In addition, the center column splits into two sections. You can use it with the short adapter and reduce the overall weight by about 9 oz. If you want the additional features of the MF3, then it is an excellent choice. The negative is the weight. You don't save much as compared to the aluminum version.
Jim
Wilt
Mar 22, 2008 14:19 |  #5
You can save additional weight by choice of a Markins ballhead rather than the RRS head.
Rey
Mar 22, 2008 16:54 |  #6
Thanks for the replies. I really liked the RRS B55 ballhead and am going to build my support system around that. I don't have the gear ATM that would necessitate that ballhead but I do plan on getting the 100-400 f4.5-5.6L IS in the future.
So does everyone agree that it's pretty much a toss-up between the two?
Rey
Mar 22, 2008 16:56 |  #7
René Damkot wrote in post #5167744 (external link)
I thought it might be the ballhead but my buddy thought it was a combination of the two but might be more because of the aluminum legs.
René ­ Damkot
Mar 23, 2008 08:02 |  #8
Post your findings, we all are curious ;)
GSansoucie
Mar 23, 2008 09:50 |  #9
I have the Bogen 055MF3 and really like it. I think the BH-55 is a lot of overkill though.
I like the horizontal position of the center post on the Bogen. For macro, it will be very useful (once the snow melts and the bugs come out).
I'm using an $89 Cullman Head with RRS Clamps and that is working quite well with my lenses (largest is the EF 70-200 F4L).
-=Glen=-
Flickr Stream (external link)
Check out my 2010 PaD (external link)
http://www.pbase.com/g​sansoucie (external link)
bikejanitor
Mar 23, 2008 13:44 |  #10
Rey;
I went thru this process about a month ago...I purchased the Feisol CT3371.
Totally satisfied; rock solid and it comes eye level (I'm 6'1") w/a Manfrotto 488rc4 (future holds a Markins for me). Total wt. 6.5 lbs., a little heavy but not so much I'll leave it behind.
I have a 40D and the 100-400IS is on the camera 95% of the time.
Great customer service by Michael at Feisol.net.
ed ­ rader
"I am not the final word"
Mar 23, 2008 14:05 |  #11
bikejanitor wrote in post #5174363 (external link)
Rey;
my manfrotto 055MF + 488RC2 without center column extension weighs 5 lbs.
ed rader
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
patrick835
Mar 23, 2008 15:14 |  #12
so are all feisol tripod made from CF? i take a look at their products and they are really light weight, around 2.6 lbs or so, and cost the same as some alloy brand name's tripods.
considering between the CT-3301 standard tripod + column and the Gitzo G2220 :D
the feisol has the larger load capacity (10kg, gitzo is 6) but i don't think it's a big deal. just because i love the light weight of CF with the same price ;) and have read some bad experiences with g2220 online lately :( seems like it it is not durable enough..
someone help me out? :(
1D mk II + sigma 10-22 + 100f/2.8 + 70-200/f4L + f/2.8L IS II+ tamron AF 2x + 430EX II
[COLOR=darkgreen] 2x Canon 30D + 2x BG-E2N + 18-55 kit + 50mm f/1.8 II + 85 f/1.8 + 100mm Macro + 70-200f/4L + 17-40f/4L + 430EX + 580 EX II + RRS L plate + Markin Q3 + Gitzo G2220
completely broke :lol:
bikejanitor
Mar 23, 2008 19:48 |  #13
Ed;
My priorities were height and sturdiness, for you to raise your manfrotto to 61"s (feisol height w/out center column) you need to raise (if you had one) the center column 8"s (according to manfrotto specs; height 53"s w/out column raised).
He asked about the ct3371, so I'm assuming he’s also referring to the manfrotto w/the center column.
So, to me, your comparison comment of 5 lbs. w/out the center column is a little misleading.
tripod to tripod according to respective site specs;
feisol 4.85 lbs. vs Manfrotto [COLOR="Red"]w/center column 055mf 4.4 lbs. 7.2 oz. difference
Head vs. head;
rc2 1.5 lbs. vs. rc4 1.76 4.1 oz. diffence.
total for all manfrotto combo 5.9 lbs. vs. feisol/manfrotto combo 6.6 difference; .7 or 11.3 ozs. more for the feisol combo.
I can't speak from experience of using the manfrotto, so I have to go by the common mantra; raising a center column will decrease a tripod’s stability.
So if he wants/needs that extra 8"s in height and purchases the manfrotto for and extra 50 bucks or so, he’ll be spending more money for less stability and 11 ozs. less in weight.
Regards
Bill
ed ­ rader
Mar 23, 2008 20:50 |  #14
bikejanitor wrote in post #5176435 (external link)
Ed;
Head vs. head;
Regards
Bill
Bill -- i was only saying what my set-up weighed. there was no ulterior motive :D.
i'm 5' 10" and my 1 d mark III's viewfinder is right at 62" on center without center column and standing erect my eye is 65" on center. you'd have to be 7' tall if the tripod was 8" taller :D.
ed rader
bikejanitor
Mar 24, 2008 07:29 |  #15
C'mon Ed, all of us non-manfrotto tripod users know how evil :evil: you manfrotto tripod users are. :lol:
I'm 6'1" ...the 40D view finder w/my set up comes to 69"s and inch higher than my eye level.
The 8"s is in addition to the base height of the manfrotto 53"s to reach the base height of the feisol's 61"s.
I apologize Ed for my clarification of the weight issue. It obviously came across to you as argumentative, hostile and insinuating a conspiratorial attitude ;)...that's the problem w/emails....you can't see the person's face and sometimes a totally innocent comment can be misunderstood. :o
Question for you Ed; how smoothly does your rc2 move?
My rc4 is a little sticky when I have the tightness set so I can move my setup and not have it fall when I remove my hands.
Rey, I apologize to you for causing this digression from your topic. But I do hope Ed and I have helped you.
Regards
Bill
7,593 views & 0 likes for this thread, 11 members have posted to it.
1390 guests, 123 members online
