Thread started 22 Mar 2008 (Saturday) 18:08
Before and After #37
thekid24
pro-zack-lee
Mar 22, 2008 18:08 |  #1
This game is to help those of us who are trying to learn new tricks when it comes to editing.
Here's the breakdown of the game. I will post a picture that I choose, resized to exactly 800 pixels maximum on the long side. Outside of being resized it has to be unedited...meaning no adjustments to any levels, it has to look like it did as it came out of the camera.
The game will last 48hrs and whoever can produce the best edited image (as judged by me) will be picked and it'll be their turn to post their unedited picture for all of us to take a crack at.
If you happen to be the winner of the game please start the next one with the title of the game and the following number. For example…the next game should read (Before and After #38)
This is all about having fun so have at it!!!
This game will end on Monday, March 24, 2008 at 10pm
TheSonofDarwin
Mar 22, 2008 21:47 |  #2
Started in Dynamic HDR to make a wide range of adjustments to the colors without cartooning it
Changed the hue of foliage to a slight red
Grabbed some CC zombies off flickr (except one which was off the interwebz)
-- Annoyingly extracted each one then decided to only use two *slap self*
Grabbed ravens similarly and extracted
Duplicated left zombie to maintain color...
B&W everything else (previous steps just pre-emptive changes for desired B&W effect)
Changed hue to grayish-blue
Monday Morning ~10% opacity
Went back to colored zombie layer:
-- ~20% Opacity + Duplicate Overlay + Duplicate Multiply
Flatten + Duplicate + Add Monochromatic noise (low opacity)
Repeat previous + gaussian blur
-50% delete left zombie to restore some detail for proximity
+ Contrast
Border+Resize
--Just wanted to note, I had absolutely no idea what to do with this picture so I took a dramatic route. Looked like a dead & deserted town, so why not take advantage of it. I was just hoping there was a closer window... I had the perfect picture in my head :lol: It seems when I don't know what to do I go the dark route.. must be my King upbringing!
-Justin (external link)
Spidy
Mar 22, 2008 22:06 as a reply to  @ TheSonofDarwin's post |  #3
It looks like the first two posts were on the same wave length :lol:
I'm not sure if I remember everything that I did, but I will give it a try ...
Cropped first
Added some lighting effects
Added a UFO
Added Ozzy
Diffuse glow
Diffuse Anisotropic
Adjusted hue and saturation
Render 3D Tranformation of the sky
And if I think of anything else ... I will post it.
This was fun :p
Debi
"Dog's have owners. Cat's have staff"
ilmk
Mar 22, 2008 22:07 |  #4
IMAGE: http://i37.photobucket.com/albums/e66/Angie1977/Smilies/yikes.gif
Goodness Sonof Darwin I wasn't expecting that one!
LOL
This should be fun... I'll edit this post when I have completed my take on the image. :)
EDIT:
- took out the stop sign and the one side of the street.
- added in sky and grass
- fixed edging
- boosted color
- added playground
- blurred tree and grass image
- softened playground image and desaturated it
- matched sky color between the two images
- ran noise remover
- new adjustment layer played with hue/saturation
- lowered transparency of that layer
- merged
- applied a boarder
- added noise
- ended there because I desperately needed to do something else.
~Angie~
Canon XTi
18-55mm
50mm
SilverHCIC
Location: Swimming, cycling or running ... somewhere in California
Mar 23, 2008 00:12 as a reply to  @ ilmk's post |  #5
Here's my go:
1. Convert original image to sepia tone
2. Divide into three portions w/ aspect ratio 4:5
3. Added white border to each followed by 5 pixel gray border to replicate Polaroid
4. Added text to bottom of "Polaroids"
5. Created new background border w/ dark blue color
6. Arranged layers to overlap 3 separate Polaroid images
7. Resize to post
"It's easy to find your bike in transition when you're the last one out of the ocean ... it's no fun being lost at sea :rolleyes:."
ZeroOne86
Mar 23, 2008 08:50 |  #6
Tried to tone map this one, but that wasn't going to work. So tried a different approach.
-Duplicated the image and created a low key filter with Nik Software
-To darken it of course what else, but a layer with a darken setting and filled in the sky with black
-With the polygonal lasso tool I chose the light and outlined a spotlight area, filled that selection with white, and then rendered some lightning effects with a light blue and white. (was going to for the newer LED light, not the old school yellow) I smudge the edges of it to blend it better
-Painted some stars in and a created a mask to fill in the areas that I wanted the stars. Added an outer glow effect on the stars
-Levels
-Border
Canon Rebel XTi 18-55mm, 50mm f1.8, 430 EX
ilmk
Mar 23, 2008 11:57 |  #7
:( I don't know why I can't see it.
It's just a black picture on this end and by your description I'm missing so much that this image is!
Is it just me or can others see it?
~Angie~
Canon XTi
18-55mm
50mm
neumanns
Mar 23, 2008 12:44 |  #8
WOW...And on a lighter side
Highlights & Shadows
contrast & Curves on stop sign
OH....And a little fertalizer applied via hue and saturation, what a chop job !
7D, Sigma 8-16, 17-55, 70-200 2.8 IS, 580ExII, ........Searching for Talent & Skill; Will settle for Blind Luck!
SQuiP
Mar 23, 2008 13:07 |  #9
Cropped image
Curve adjustment, color boost
Added layer #1 in lawn area
Added painted layer #2 for sky and front lawn
Additional saturation on stop sign (marquee)
Diffuse and blur sky
...or something like that :)
Ilse
http://www.gingeralear​t.co.za (external link)
TheSonofDarwin
Mar 23, 2008 13:08 |  #10
ilmk wrote in post #5173776 (external link)
Try viewing it in a totally dark room, then you'll see it. Otherwise light glare kills it.
ZeroOne86
Mar 23, 2008 13:31 |  #11
Yeah even on my laptop I can see it and it's infamous for being dark. Then again our computer room is like the bat cave. I'd try thesonofdarwin's suggestions.
BitterSweet
Mar 23, 2008 18:39 |  #12
At first I didn't think I was going to be able to do anything with this one because I couldn't figure out how to get my ideal onto the screen but finally figured something out.
-Added graveyard ( picture from laterose-stock on deviantart)
-Added tree
-added clouds and lighting
-turned the whole thing b&w
-used a bleach bypass filter
-added fog
-added vignette and border
Tracey McCloskey
www.Bitter-Sweet-Photography.com (external link)
Model Mayhem Link http://www.modelmayhem​.com/bittersweetphotog​raphy (external link)
thekid24
pro-zack-lee
Mar 24, 2008 20:37 |  #13
TheSonOfDarwin won this comp.
The edit initially made me go 'what tha hell?!" and after looking it over made me think of the vidgy game House Of The Dead.
Congrates...all very creative edits...which I always like to see.
ilmk
Mar 24, 2008 20:42 |  #14
Congratulations TheSonOfDarwin!!
What a fantastic imagination. I agree thekid24, it also made me go YIKES at first but it's nicely made up and excellently creative!
~Angie~
Canon XTi
18-55mm
50mm
BitterSweet
Mar 24, 2008 21:08 |  #15
congrats TheSonofDarwin you're looked really cool.
Congrats to everyone else too.
Tracey McCloskey
2,658 views & 0 likes for this thread, 10 members have posted to it.
1588 guests, 139 members online
