Well, I got really bored while waiting for the rest of my lighting set up to be delivered, so I decided to use my restless energy on a couple of foamcore reflectors...
As for the full length reflector panel, I could have built a 4x8' "bookend," which is easier and simpler, but I opted for a panel for its multipurpose, as well as its modular, uses. After I built this, I found Robert's (TMR Design) old posting about the same project except much better than mine. So if anyone's interested in this project, take a look at his as well here:
https://photography-on-the.net …91552&highlight=reflector
The similarities between his and mine are the material and its modularity and multifunctionality. The differences are that I used 1/2" PVC tubing (his is thicker, I think) and hung with a couple of rings through corner holes that are protected from wear and tear with 1/8" white fashion eyelets. All four corners have the eyelets in case I want to tie all four corners.
The panel can go taller or shorter by simply taking the couplers off on both legs and adjusting the height with whatever length tubes... I decided to hang (rather than attaching) the foamcore in order to be flexible, i.e., you can hang a black foamcore on the reverse side through the same rings, or take the whole thing off and use a fabric or whatever the situation calls for....
This one's for filling the shadows from angled positions (chin shadow, etc.). I almost threw this music stand when it broke on my boys about a year ago, but something told me to keep it for some other possible use.... Well, I'm glad I didn't throw it away, as it's perfect for low angle reflector use. This music stand can be purchased new for less than $10 or get it for a couple of dollars at garage sales. Just make sure to get the one that controls the angle. This thing can angle to a horizontal position. I used a couple of self-adhesive velcro to connect the board and the music sheet support. Again, I didn't want it to be permanently fixed unit in case I want to use the thing for some other purposes....
