Thread started 23 Mar 2008 (Sunday) 21:09
IR Filters - INFRARED Help?
Adaptive
don't defend yourself, call modday
Mar 23, 2008 21:09 |  #1
I want to get a IR filter.
Here is the list on B&H for list of 77mm filters. What is the good one to get?
There is like 4 or 5 different B+W ones, and 2 Hoya ones that are more expensive than the B+W filters??
Don't know which to choose?
http://www.bhphotovide​o.com …&basicSubmit=Su​bmit+Query (external link)
Adaptive
Mar 23, 2008 23:35 |  #2
no one?
lehayes
Mar 24, 2008 07:01 |  #3
I purchased the Hoya R72 filter and it works great except for the fact that you have to compose your shot, screw on the filter, expose for approximately 20 seconds. I don't like not being able to compose and fire away so I had my original Digital Rebel converted to IR through Lifepixel and I love it. Bottom lline, the Hoya R72 filter works good for IR, but having a converted camera works great. The first photo was taken using the converted camera, the second one was taken using R72.
IMAGE: http://i163.photobucket.com/albums/t312/Larbear3/IR/blackangel2IR_w.jpg
IMAGE: http://i163.photobucket.com/albums/t312/Larbear3/IR/BlackHawkIR_w.jpg
Larry
Midwest Freelance Photography (external link)
Canon IR Digital Rebel, 20D, 40D, 100-400 L IS, 70-200 f2.8 L, 24-70 f2.8 L, 100mm Macro f2.8, 50mm Macro f2.5, 50mm f1.4, 17-85mm IS, 10-22mm f3.5-4.5, 1.4x TC, 420ex, 580ex, Adobe Photoshop CS5, Lightroom & other assorted goodies..
argyle
Mar 24, 2008 09:56 |  #4
Adaptive wrote in post #5176986 (external link)
I tried the Hoya R72 (77mm) several months back but decided to go with a converted body instead. If you just want to dabble in IR, a filter is probably the way to go, even with its limitations. If you want to get into IR deeper, then a converted camera body is definitely the way to go.
Filter limitations: long exposure times, tripod will be necessary, you may have to compose, focus, and then attach the filter. AF may be ineffective. Also, if foliage is in your pictures, any breeze will cause it to move during the long exposure and will appear OOF in the final image (same for cloud movement).
Converted body: 'normal' exposure times, meter through the lens, AF, a tripod not always necessary.
johneo
Joined Aug 2003
Mar 24, 2008 17:37 |  #5
Been the same route as the replies above! Only difference is I bought a 58mm Hoya R72 filter to test / try IR photography instead of spending what a 77mm filter costs. Decided before buying a 77mm that spending that much (and a little more) on a conversion of my old 10D was a much smarter idea. Found out it is a MUCH easier process to get an IR photo too!
The above described method does not compare in any way to having a walk around IR digital camera ... just point and shoot, like you would any digital SLR! (with minor adjustments)
2 - 5DMKII's, Powershot SX 150 IS
7D, 5D, IR/5D, 10D, IR/10D, Elan 7NE
17-40 L, 24-70 L, 70-200 f/2.8 L IS, 100-400 L IS,
TS-E 24 f/3.5 L, 28-135 IS (x2), 50 f/1.8, 85 f/1.8 550EX, 430EX
40mm pancake
1,842 views & 0 likes for this thread, 4 members have posted to it.
1061 guests, 115 members online
