Thread started 08 Nov 2004 (Monday) 05:11
A little Monday morning humor
pcasciola
POTN SHOPKEEPER
Joined Sep 2004
Nov 08, 2004 05:11 |  #1
I was browsing J&R's site, and I came across an EF-S 10-22mm, allegedly for a Digital Elph or a 20D. Now, I've seen the Digital Rebel called a lot of bad things in my day, but NEVER a Digital Elph. :lol:
http://www.jr.com …e.process?Produ​ct=4008477 (external link)
Philip Casciola
Pro Camera Gear (external link) - POTN Shop (external link)
Canon 7D, EF 50/1.8, EF 85/1.8, EF 300/4L IS, EF-S 18-55, Tamron 28-75/2.8, EF 70-200/2.8L IS
Sigma 1.4x & 2x, Tamron 1.4x, Gitzo 2220 Explorer, 322RC2 grip
photography ­ By ­ Evangelos
Joined Jan 2003
Nov 08, 2004 06:48 |  #2
LOL :D Good one!
Angelo 8)
cmM
Joined Apr 2004
Nov 08, 2004 07:47 |  #3
LMAO!!!!
Digital Elph :P
thomascanty
Bold. Pink.
Gone, but not forgotten.
Joined Mar 2003
Nov 08, 2004 10:21 |  #4
Hey, I have a Digital Elph (S330)! How do I make that lens work with it? :lol:
booggerg
Joined Aug 2004
Nov 08, 2004 10:30 |  #5
Wow the crop factor still applies to EFS? :lol:
"Equivalent to a 16-35mm zoom"
20D || EOS650 || 50 f/1.8 MKI || 17-40 f/4L || 70-200 f/4L || Sigma 35-135 f/3.5 || Yashica Electro 35 || Yashica Minister || Yashica Mat 124G || Hoga 120CFN || 420EX || Sekonic 306 || Panasonic DVX100 || Canon GL2
Jon
Joined Jun 2004
Nov 09, 2004 10:25 |  #6
Yeah. Focal length is an absolute metric. a 10 m lens will always have a focal length of 10 mm. "Crop factor" really relates the sensor sizes of the respective cameras (linear 24 mm/15 mm = 1.6x). The angle of coverage of a 10 mm lens on a D30/D60/DR/10D/20D is, because of the smaller sensor, equivalent to the angle of coverage of a 16 mm. lens on a full-frame 35 mm SLR.
Jon
Cocker Spaniels
booggerg
Joined Aug 2004
Nov 09, 2004 11:12 |  #7
I thought the EFS series lenses are made for 1.6x crop factor cams. So the 10mm ought really be a 10mm.
Persian-Rice
Joined Apr 2004
Nov 09, 2004 11:28 |  #8
Wouldnt a 20D be called the elph? they feel like a big P&S........
Jon
Joined Jun 2004
Nov 09, 2004 12:04 |  #9
They're made for the 15 x 22.5 mm sensor of the "1.6x crop factor" cameras. They can't cover a full 24 x 36 mm frame/sensor. They still have a real focal length of 10 mm, unlike the PowerShot P/S line where they advertise a "35 mm equivalent" focal length. But they're no different in coverage than a full-frame 10 mm. lens would be on a DR/20D. A picture taken with the new 17-85 EF-S at 17 mm will look identical in coverage to one taken by a 17-40 EF L at 17 mm, or Drisley's new love, the 17 mm Tokina prime on a DR or 20D. It doesn't matter that the one is EF-S and the other two are EF (full frame).
Jon
Cocker Spaniels
booggerg
Joined Aug 2004
Nov 09, 2004 14:26 |  #10
I do'nt understand, I thought these lenses are made for 1.6x sensors, so shouldn't they focus their image onto a smaller size? So you'd be getting the full 10mm field of view instead of a 16mm field of view. So setting the EFS 10-20mm to 17mm on a 20D, you'd get the identical field of view as a 17-40mm L set to 17mm on a 1DS. Correct?
Jon
Joined Jun 2004
Nov 10, 2004 08:52 |  #11
No. Focal length is an absolute measure of the distance between the optical center (nodal point) of the lens and the point at which a light source at infinity will focus. So a 10 mm lens will focus the light from the sun 10 mm from the optical center of the lens. A 16 mm. lens will focus it at 16 mm. from the optical center of the lens. And a 100 mm lens will focus it at 100 mm from the optical center of the lens. It has no bearing on how large an area a lens is able to illuminate (cover).
[aside]"Nodal point" isn't the same as the middle of the SLR lens, they play some tricks in the design of modern lenses to get something called "retrofocus", where the nodal point of a complex lens is physically outside the lens proper. You'll see focal length most easily with a simple magnifying glass, a close-up lens, or a pair of reading glasses (the reading glasses' "diopter" is 1/focal length in meters) in the sun. [/aside]
The lenses being "designed" for different sensor sizes means that they can provide uniform illumination across (cover) a different amount of the sensor area. So "designed for 1.6x sensors" just means that the lens is only designed to "cover", or illuminate the 15 x 22.5 mm area of the DR/20D's sensor. It doesn't mean that it bends the light more than another lens would, to give you a larger angle of view. If it could bend the light more than the other lens, it'd actually have a different focal length. This coverage is sort of backwards vignetting (where a lens hood or filter gets included in the picture, so you get dark corners) if you like.
A 16 mm. lens designed for a DR/20D's smaller sensor will not even pretend to be able to cover (project the image on) a larger sensor area. If you were to put it on a standard 35 mm Eos, you'd see a circle in the center of the frame with black around the edges where the lens can't "cover". A 16 mm lens designed for a 35 mm camera will be able to "cover" the whole 35 mm frame evenly, with no blacking out at the corners.
But if you put either of them on a 20D or DR, they'd take exactly the same picture. And that picture would include exactly what you would see if you used a 25.6 mm (1.6x, remember) lens on a full-frame 35 mm camera at the same place. If you were able to put that 16 mm (1.6x crop) lens on an Eos full-frame camera, take a picture, change to a full-frame 16 mm lens on the same camera and take another picture, then superimpose the two images, they'd match perfectly.
Jon
Cocker Spaniels
3,174 views & 0 likes for this thread, 7 members have posted to it.
2570 guests, 94 members online
