hello, i was wondering if anyone could help me with my problem. I'm hoping that i'm being me as usual and there is some sort of obvious solution that i am overlooking cause i like to panic when expensive toys aren't acting right
So i picked up the camera for the first time in a long time this afternoon and started playing with my flash ( 580 Ex II ). i took a number of shots that were perfectly exposed. I put the camera down for a min to adjust subject, come back and the flash says TTL and not ETTL, completely blowing out my shot
Somehow it fixed itself, and i kept shooting figuring it was a fluke. When it happened again i looked at the flash again it said TTL... the pilot light was on so i pressed it to see if the flash would fire, it didn't however it then switched back to ETTL.
Anyone have the same experiences?? Please forgive me if this was already covered in another post, i did a search and the only post i saw about issues with the 580EX II was to clean the contacts, witch i did with the same results
Thanks for your time
Mike
