Bosscat wrote in post #5189709
When I follow the recommendations for the container size, I don't get the same numbers on both dimensions as they prescribe. Plus whenever I change both numbers to match the prescribed size, I get a image that gets distorted.
You first have to crop to fit the aspect ratio that's required, then you resize to fit the actual dimensions.
There are numerous "standard" sizes that don't have the same aspect ratio, e.g. 4x6, 5x7, 8x10, 12x16 all are common print sizes that have different ratios. The only one of these that a Canon DSLR will match out-of-camera is the 4x6 (or by enlarging a 12x18). I don't know how exactly the images will match the 2x3 proportion, though.
At any rate, at any proportion other than 2x3 you'll have to crop off the long dimension at the ratio you need then resize to the dimension and the 300 ppi pixel density you need.
Hope this helps!
