I'm about to use my 20D with my Bowens flash heads for a portrait session.
The standard colour temp on the camera is set 5200K - Do I need to change the setting in the studio?
Mikey-2u Member 49 posts Joined Dec 2003 More info | Nov 09, 2004 06:40 | #1 I'm about to use my 20D with my Bowens flash heads for a portrait session.
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Nov 09, 2004 11:29 | #2 Yes - Bowens gives their colour temperature at 5800K. Electronic flash in general is cooler than daylight. Jon
DaveG Goldmember 2,040 posts Likes: 1 Joined Aug 2003 Location: Dartmouth, Nova Scotia More info | Nov 09, 2004 12:05 | #3 Mikey-2u wrote: I'm about to use my 20D with my Bowens flash heads for a portrait session. The standard colour temp on the camera is set 5200K - Do I need to change the setting in the studio? Do a test shoot without any type of colour temperature "corrections". "There's never time to do it right. But there's always time to do it over."
Jesper Goldmember 2,742 posts Joined Oct 2003 Location: The Netherlands More info | Nov 09, 2004 12:44 | #4 You'll get the most accurate colours if you use custom white balance. On the 10D, and it's probably the same on the 20D, you do this by making a photo of a white or neutral gray object under the lighting that you want to use, and in the menu of the camera set the white balance to Custom, and choose the image of the neutral object as the reference point - look it up in the manual of your 20D. Canon EOS 5D Mark III
| Latest registered member was a spammer, and banned as such! 2570 guests, 94 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
