Thread started 26 Mar 2008 (Wednesday) 13:23
40D and 580EX
sam0329
Mar 26, 2008 13:23 |  #1
Hi,
Can someone tell me how to set 2nd curtain sync on the 40D with 580EX? It works on my Mark III and 30D and I have no idea why its grey out on the 40D. Please advice. BTW I have the lastest firmware I beleive its 1.0.5. Thank you alot!
Sam
PacAce
Joined Feb 2003
Mar 26, 2008 14:35 |  #2
Did you check to make sure that the 580EX is not in Master or Slave mode?
...Leo
sam0329
Mar 26, 2008 16:01 |  #3
Nope, its not in master or slave mode and it still not working...
MarkNDixie
Mar 26, 2008 16:08 as a reply to  @ sam0329's post |  #4
I think that only works with the 580EX II, not the original 580EX. It's grayed out on mine as well. You will have to set it on the flash itself.
-mark
EOS 40D, EF-S 10-22 f/3.5-4.5, EF 16-35 f/2.8 L, EF 24-70 f/2.8 L, EF 100 f/2.8, EF 70-200 f/2.8 L IS, EF 300 f/4.0 L IS, EF 100-400 f/4.5-5.6 L IS, EF 50 f/1.8
PacAce
Joined Feb 2003
Mar 26, 2008 16:21 |  #5
You should still be able to set the 2nd curtain sync function on the body, though. Maybe it needs to be set from the "Built-in flash func setting" option instead of from the "External flash func setting" option.
...Leo
MarkNDixie
Mar 26, 2008 16:25 as a reply to  @ PacAce's post |  #6
Good thought PacAce, but I tried it and I get a "This menu cannot be displayed. External flash is attached" message.
-mark
PacAce
Joined Feb 2003
Mar 26, 2008 16:30 |  #7
MarkNDixie wrote in post #5197060 (external link)
-mark
Well, so much for that idea. What I find perplexing is why the 1DmkIII allows 2nd curtain to be set via the camera but the 40D won't. :confused:
...Leo
MarkNDixie
Mar 26, 2008 16:42 as a reply to  @ PacAce's post |  #8
Agreed PacAce. It looks like the 40D and the original 580EX only will let you set FEC and E-TTL II metering mode via the camera menu. All the other options are grayed out.
-mark
steved110
Mar 26, 2008 18:41 as a reply to  @ MarkNDixie's post |  #9
Strange little glitch - but I assume you can set 2nd curtain synch on the flash itself easily enough?
i've always done it that way, less to trawl through!
Canon 6D
Canon EF 50mm f/1.4 , Canon EF 85mm f/1.8 Canon EF 100mm f/2.8 macro
CanonEF 17-40 f/4 L Canon EF 24-70 f/4 IS L and 70-200 f/4 L :D
Speedlite 580EX and some bags'n pods'n stuff
MarkNDixie
Mar 26, 2008 18:56 as a reply to  @ steved110's post |  #10
Oh yes. Two pushes on the High Speed Sync button on the back of the flash and you're there. Quicker than navigating the menus on the camera IMHO.
-mark
PacAce
Joined Feb 2003
Mar 26, 2008 20:26 |  #11
Well, I just tried to set the 2nd curtain sync on my 1D3 via the external flash settings menu and could not (for a non-580EX II flash). The only way to set 2nd curtain sync on the 1D3 is via custom function C.Fn II-5 = 1. Unfortunately, the 40D does not have an equivalent custom function option.
...Leo
sam0329
Mar 27, 2008 00:03 |  #12
Thank you guys. It just kind of stupid because Canon is trying to push me to upgrade all my flash...
John_B
Gallery: 178 photos
Mar 27, 2008 06:18 |  #13
sam0329,
Yea it surprised/aggravated me when I couldn't get 2nd curtain sync with my 580ex :mad: When I could on my 5D and 10D from the camera.
click to see (external link)
PacAce
Joined Feb 2003
Mar 27, 2008 08:23 |  #14
John_B wrote in post #5201208 (external link)
sam0329,
You mean you couldn't get 2nd curtain sync via the camera, right? Because you can set 2nd curtain sync on the flash itself which is easier and faster to get to than via a camera menu or custom function. And the flash setting always overrides the camera setting for 2nd curtain sync if the flash has this feature which is true for all current EX flashes other than the 220EX. In other words, the 2nd curtain sync via the camera is useless for all current EX flashes because the flash setting will always override it. It is only useful when used with the 420EX and lower models which don't have the 2nd curtain sync feature on the flash.
...Leo
John_B
Gallery: 178 photos
Mar 27, 2008 16:28 |  #15
PacAce,
:lol: Yes, via the camera, I already knew about the on flash setting ;)
Thanks anyway :)
2,319 views & 0 likes for this thread, 5 members have posted to it.
40D and 580EX
658 guests, 120 members online
