Thread started 09 Nov 2004 (Tuesday) 17:10
Is this the best decision?
jaypie77
Joined Aug 2004
Nov 09, 2004 17:10 |  #1
I have pretty much decided that I will sell my EF 55-200 and put that money towards a 70-200 F4. I've decided this because I think that the image quality will be a huge improvement, but I also think that a 70-200 is a more useful lens than a 100mm macro or waiting and saving for a 100-400 (which could take a while) or some other expensive option. Am I making the right move?
jaypie77
Joined Aug 2004
Nov 09, 2004 17:11 |  #2
CRAP - I forgot to add this:
Somebody mentioned an option for macro that involved screwing on a filter-type of thing that would connect two lenses end-to-end and would give you a macro effect. Is this for real? Is this any good?
commando
Joined Oct 2004
Nov 09, 2004 17:15 |  #3
That 55-200 costs like $190 new, so would could you get used? $150? $100? The 70-200 new is $570 or so, so whatever you get for the 55-200 would only be a drop in the bucket towards it. The question is would you rather have the $100-$150 or the lens?
HJMinard
Joined Jan 2004
Nov 09, 2004 17:15 |  #4
Yes.
~ Jay ~
Canon EOS 20D ... lenses and stuff
Without the Way, there is no going; Without the Truth, there is no knowing; Without the Life, there is no living. <><
Help remove children from poverty: Compassion (external link)
jaypie77
Joined Aug 2004
Nov 09, 2004 17:24 |  #5
So it's a done deal then. I'm going to sell this thing and get a nicer lens.
And regarding the second question?
HJMinard
Joined Jan 2004
Nov 09, 2004 17:25 |  #6
I'm not sure if the device you mention exists, but other options include:
(1) close up lenses (external link) - which you would use with a 67 to 77mm step-up ring on the 70-200/4
(2) extension tubes (external link)
~ Jay ~
jaypie77
Joined Aug 2004
Nov 09, 2004 17:30 |  #7
Jay,
Thanks for the answer, but your link to the extension tubes actually brought me to my answer: they are called "reversing rings" and they are cheap (unless you want AF, which is pricey).
So, I guess the next question is: Does anybody have experience with Reversing Rings?
jaypie77
Joined Aug 2004
Nov 09, 2004 17:35 |  #8
Oops, I was mistaken. Reversing rings are different, what I am actually looking for are called "MACRO COUPLERS."
http://www.bhphotovide​o.com …avBar&A=search&​Q=&ci=3066 (external link)
wolf
Joined Sep 2004
Nov 09, 2004 18:31 |  #9
Using this method really limits the DOF and the working distance to the subject also the reversed lens needs to be a fairly fast lens (f1.4) or you will get bad vignetting. The lens I use with my 300D kit lens and the G5 is a Pentax 50mm f1.4 and a homemade reversing ring (couldn't find a 58-49 ring).
Here (external link) is a good read about different methods for macro photography.
<> My Gear <>
jaypie77
Joined Aug 2004
Nov 09, 2004 18:47 |  #10
Awesome, thanks for the information. So, any thoughts on maybe keeping the 55-200 and using it with my 50mm 1.8 in a coupler situation? Or should I use my kit lens for that? Or a 75-300?
wolf
Joined Sep 2004
Nov 09, 2004 19:28 |  #11
I just tried the 70-300 and the 50 f1.8 reversed (hand held together) and that is a good combination. If you already have a 75-300 I would use it, if not then try the 55-200. The kit lens with a 50 reversed doesn't give you all that much spread in magnification like the 75-300 would.
<> My Gear <>
1,727 views & 0 likes for this thread, 4 members have posted to it.
2570 guests, 94 members online
