Skids wrote:
HI.
I am a little confused over the correct use of my Stofen Omnibounce and would like some advice on it.
I am going to a motorbike show on Friday and will be photographing both Bikes and Models.
On other posts it says that the Omnibounce is only used in conjuction with bouncing off of walls and ceilings is this correct and would that mean that, because this venue will have very high ceilings, I would be better off not using the Omnibounce at all or should I keep it on and point the flash directly at the subject?
By the way I am using an EOS300D with a 550EX.
Many Thanks
Darren
In a big room with no bounce potential I'd normally leave the Stofen off of the flash. As others have said it's just weakens your flash. The only two things that will make light softer is size and proximity. A big umbrella or big softbox will give you soft light. A small umbrella will give soft light if it's very close to the subject. A big, big light will be harsh if it's too far away (i.e. the sun).
But I also used my Stofen as a wide angle diffuser when I was using a 20mm lens on film Nikon, with a Vivitar 283 flash. The wide angle flip diffuser built into the 550EX flash has been wide enough to forgo this with my 16-35, but I suspect that I may need the Stofen again when I get the 10-22.
"There's never time to do it right. But there's always time to do it over."
Canon 5D, 50D; 16-35 f2.8L, 24-105 f4L IS, 50 f1.4, 100 f2.8 Macro, 70-200 f2.8L, 300mm f2.8L IS.
